Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Old 12-18-2013, 10:58 PM
  #41
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Originally Posted by Sam Handwich
Gene,
How long are these sway bar prices good?
How does one decide (or know) if new end links are needed?
Also, how long does it take to swap each bar?
thanks,
ScumOne gave you some great install advice! The sale is good until the end of the month.
If you have plastic end links I would replace with the latest GM end links and if you have metal end links that do not make any noise then I wouldn't spend the money on new.!
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 12-27-2013, 01:28 AM
  #42
Jistari
Jistari's Avatar
Originally Posted by ArtGle
O.K., so I'm putting my C-5 Base Coupe up for the winter.
Just bought it a month ago.
Active Suspension is fully functional, and I'd rather not remove it.
When I PUNCH it, display states "Active Suspension On" and changes back to odometer.
Are these C6 Z06 shocks going to work with this?
Newbie here, so stop laughing.
109K miles, and shocks are kinda "Skooshy", (mild up and down on highway, makes me nervous with that 'Floating' feeling).
So I know the shocks need replacing.
We have Active Handling (which does differential braking to correct your line based on the position of the steering wheel and speed of each wheel) and also Magnetic Selective Ride Control which applies a voltage to the special fluid in the shocks to change the viscosity (and hence the "stiffness" of the shock. But we don't have Active Suspension.
If you have the ride select switch on the center console, then you have the Magnetic Ride. This feature is not available if you swap out to the C6 Z06 shocks.
Now having said that, if your magnetic shocks are shot, they are quite costly to replace (probably four times what the C6 ones cost).
I didn't have the Selective Ride option, so when I replaced my base shocks I went with the C6 ones. Could not be happier
The C6 Z06 shock is bolt in compatible and just works better, excellent ride, not too stiff, very flat ride, great when you push it.
That with the C6 Z51 sway bars (not the Z06 bars, Z51 is the thickest bar you should go with with stock width tires, wider is not better in this case) and the metal end links you really get a much better ride. Nice and flat/tight.
Couldn't be happier with this mod
Old 12-27-2013, 09:03 PM
  #43
Gene Culley
Great feedback and review! Thank you very much!
Old 01-04-2014, 10:55 AM
  #44
Sam Handwich
Sam Handwich's Avatar
Default December pricing?
Originally Posted by Gene Culley
Order your suspension upgrade from GM Parts House.
So of the prices that were set to expire January 1st, which are being extended? And for how long?
Old 01-04-2014, 11:46 PM
  #45
elcajonblvd
elcajonblvd's Avatar
I have base 2007 C6 can only do sway bars OR shocks right now, so whats the 1rst one to be done...errr or which is still on sale
Old 01-10-2014, 11:29 PM
  #46
Gene Culley
The cost to us has gone up January 1st. If you are interested in ordering I would do so before I have the opportunity to change the price.
Old 01-10-2014, 11:30 PM
  #47
Gene Culley
I would get the sway bars first since they are about to go up $30 per the kit or so.
Old 01-11-2014, 10:30 AM
  #48
ScumOne
ScumOne's Avatar
Just an update on my Z51 sway bar/Moog end link upgrade to my 99 C5. I had the opportunity last night to make a right hand turn at a deserted street corner at 35 mph with the new upgrades.
It felt and handled the same (or better) than my 04 Le Mans CE with 35k miles.
The 99 C5 has 84k miles.
Needless to say, that upgrade was well worth the 2 hours of labor and sub $300 price tag for all of the parts.
Old 01-11-2014, 09:03 PM
  #49
About2Bite
About2Bite's Avatar
2012 C6 Z06 Shocks!
We sell the 2012 C6 Z06 shocks for $254.60. Many C5 customers ask us why we don’t recommend the 2004 shocks over the 2012. Many people also say that the C6 shocks are only developed for the C6. If you look at all of the basic suspension components between the C5 and C6, they are very much the same. The reason we don’t recommend the 2004 Z06 shocks over the 2012 C6 Z06 shocks is simply because of the price and customer feedback. We have many customers who have tried both sets of shocks and cannot tell the difference between the two, so why not purchase the lesser expensive set!
Thanks. Gene.
||--Genuine GM 2012 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) $254.60 total.
For the shocks on our website, use part number c6z06shocks under Chevrolet make.
The C6 Z06 shocks will work on stock C5’s and C6’s without modification.
Do you know if these shocks are the same length as the stock setup?
Also, do you offer a shorter set that would work better on a lowered C5?
Thanks,
Old 01-15-2014, 10:53 PM
  #50
Gene Culley
Thank you for your valuable feedback.
  #51
Gene Culley
Thanks,
They are very slightly longer than the stock shocks and we don't offer any other lengths.
Old 01-17-2014, 02:14 PM
  #52
Elizabeth City Vette
Elizabeth City Vette's Avatar
Ordered the shocks today for my 2004. Sounds like this is the way to go to get rid of the selective ride shocks. One leaky shock was going to cost $750 just for the shock. I found someone with a Tech 2 so the simulators are not needed either.
Old 01-17-2014, 03:13 PM
  #53
GoatKart
GoatKart's Avatar
Gene,
maybe a stupid question, as its a bit early.... Have you checked the C7 bits yet to see if the sways will fit? Not sure if they changed them for the new model or not?
Old 01-17-2014, 10:06 PM
  #54
Gene Culley
Thank you for your business. I certainly appreciate it!
  #55
Gene Culley
Originally Posted by GoatKart
Gene,
We do not have any supporting data at this time.
Old 01-19-2014, 03:40 PM
  #56
CoupeC5man
CoupeC5man's Avatar
St. Jude Donor '07
Just ordered a set of ZO6 shocks today, Can't wait to get them on this spring.
Old 01-22-2014, 10:26 PM
  #57
Gene Culley
Thank you for your business. I certainly appreciate it.
To Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Old 01-31-2014, 09:49 PM
  #58
Gene Culley
Thank you for all of the orders on these kits. This is a very inexpensive and very effective upgrade!
Old 01-31-2014, 10:03 PM
  #59
Sam Handwich
Default very happy with the new sways
With the new sway bars it is a different car. Not sure why I would need new shocks - the car has less than 33k miles from new. Maybe after I get tires in a few months I will consider it.
thanks Gene!!
Old 02-07-2014, 11:14 PM
  #60
Gene Culley
thanks Gene!!
Thank you for your business and the positive feedback. Once you get the shocks you will be totally pleased!
Quick Reply: Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
