Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
#122
Premium Supporting Vendor
The sway bar upgrade will significantly reduce that body roll!
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
#123
2013 C6 Z51 Sway Bars!
Greetings Friends,
We have the Z51 sway bars kit with the Genuine GM bushings for $230.39.
The reason people use these bars most on the C5’s and the C6’s is because unless you’re running 335 width tires in the rear, these are the way to go. These bars don’t cause the vehicle to ride “stiffer” per se. They are mostly for the cornering ability.
You know that feeling when you’re going into the turn and the car leans pretty heavily? These bars are meant to make the vehicle feel flatter in the turns and corner much better in the turns. Another advantage is the handling when you’re coming out of the turn. When you come out of the turns you will not be fighting the wheel as much as you would with the stock bars. These bars, since they’re thicker, make it easier all the way through the turns.
Below are the specifications and comparisons of the C6 Z51 sway bars compared to other Corvette suspension packages.
Corvette Sway Bar Specifications
Suspension Front (mm) Rear(mm)
C5 base 23.0 19.1
C5Z51 (97-99) 25.4 21.7
C5Z51 (00-04) 28.6 23.6
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
We offer these sway bars with the 2013 C6 Z06 shocks. Also, whether it is a C5 or C6, coupled with the 2013 C6 Z06 shocks it makes a total different handling package. This package speaks for itself as we have many testimonials from many customers from whom we sold these to here on the forum!
To order, please call 484-949-2099 or go to www.gmpartshouse.com and use part number c6z51bars and be sure to select Chevrolet make.
Thanks. Gene.
||--Genuine GM C6Z51 Sway Bar Kit--||
25919502 – Front stabilizer bar
10339124 – Rear stabilizer bar
10387838 – Front stabilizer bar bushings (2)
15241135 – Rear stabilizer bar bushings (2)
Complete kit front and rear is $230.39
Use part number c6z51bars on our website under Chevrolet make.
2013 C6 Z06 Shocks!
We sell the 2013 C6 Z06 shocks for $265.68. Many C5 customers ask us why we don’t recommend the 2004 shocks over the 2013. Many people also say that the C6 shocks are only developed for the C6. If you look at all of the basic suspension components between the C5 and C6, they are very much the same. The reason we don’t recommend the 2004 Z06 shocks over the 2013 C6 Z06 shocks is simply because of the price and customer feedback. We have many customers who have tried both sets of shocks and cannot tell the difference between the two, so why not purchase the lesser expensive set!
For the C5, not C5 Z06, we also recommend the C6 Z51 sway bar kit. The C6 Z51 sway bar kit coupled with the 2013 C6 Z06 shocks is our most popular suspension and handling upgrade for the C5.
To order, please call 484-949-2099 or go to www.gmpartshouse.com and use part number c6z06shocks and be sure to select Chevrolet make.
Thanks. Gene.
||--Genuine GM 2013 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) $276.74 total.
For the shocks on our website, use part number c6z06shocks under Chevrolet make.
The C6 Z06 shocks will work on stock C5’s and C6’s without modification.
We no longer offer PFADT poly bushings with the sway bar kit or any other PFADT products.
Greetings Friends,
C5 base 23.0 19.1
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
Thanks. Gene.
2013 C6 Z06 Shocks!
Thanks. Gene.
#125
Z51 Sways with F55
Any feedback from those who have added Z51 bars to a Base C6 with the F55 option?
Would you recommend the newer end links on a 2009?
Thanks for all you do for the Corvette community.
#128
O.K., so I'm putting my C-5 Base Coupe up for the winter.
Just bought it a month ago.
Active Suspension is fully functional, and I'd rather not remove it.
When I PUNCH it, display states "Active Suspension On" and changes back to odometer.
Are these C6 Z06 shocks going to work with this?
Newbie here, so stop laughing.
109K miles, and shocks are kinda "Skooshy", (mild up and down on highway, makes me nervous with that 'Floating' feeling).
So I know the shocks need replacing.
Hoping to do the shocks in 2015.
#129
If you have the magnetic suspension you can still purchase the C6 Z06 shocks and install shock simulators so the system still thinks the electronic shocks are still installed.
You'll have a totally new handling car with the combination I am selling here.
#130
Clutch Package
Gene my LS-6 03 Z hydraulics for the clutch have finally failed. I am in the market for a complete LS-7 package including a slave cylinder, master cylinder, clutch, pressure plate, bolts, pilot bushing and alignment tool. Could you PM me a turn key price for all of the pieces shipped to my door, a stock flywheel is fine with me. My zip is 30019 I can not navigate your web site for some reason. Thank you for your help.
#131
The thread below has all of the prices that you're asking for.
https://www.corvetteforum.com/forums...rformance.html
If you click or are able to click on our website page below you can see the options with the different bolts that we offer.
http://www.cultragfactoryparts.com/c.../ls7clutchkit/
Thank you,
Gene.
#132
Order your suspension upgrade from CULTRAG Performance!
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
#133
Greetings Friends and Patrons,
P.S. This sale and promo code is for anything that can be ordered on the website and does not include any orders before or after the dates and times given. 2015 C7 Corvette Z06 parts are excluded from the sale and any orders placed using the promo code for any of those parts will be cancelled and refunded.
#134
That is up and coming. We are going to develop another website for that and they will be linked to one another. That is my beginning of the year project. Until then please contact Patrick, patrick@cultragperformance.com, and he will take care of you on the mats with the discount.
#135
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Finally! A C5 vendor offering reasonable prices!
C6Z51 on order!
C6Z51 on order!
#136
Greetings Friends,
We have the Z51 sway bars kit with the Genuine GM bushings for $245.53.
The reason people use these bars most on the C5’s and the C6’s is because unless you’re running 325 width tires in the rear, these are the way to go. These bars don’t cause the vehicle to ride “stiffer” per se. They are mostly for the cornering ability.
C5 base 23.0 19.1
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
To order, please call 484-949-2099 or go to the link below to order!
http://www.cultragfactoryparts.com/c...kit/c6z51bars/
Complete kit front and rear is $245.53
Use part number c6z51bars on our website.
2013 C6 Z06 Shocks!
We sell the 2013 C6 Z06 shocks for $294.94 Many C5 customers ask us why we don’t recommend the 2004 shocks over the 2013. Many people also say that the C6 shocks are only developed for the C6. If you look at all of the basic suspension components between the C5 and C6, they are very much the same. The reason we don’t recommend the 2004 Z06 shocks over the 2013 C6 Z06 shocks is simply because of the price and customer feedback. We have many customers who have tried both sets of shocks and cannot tell the difference between the two, so why not purchase the lesser expensive set!
http://www.cultragfactoryparts.com/c...t/c6z06shocks/
Both sets of front and rear shocks (4) $294.94 total.
For the shocks on our website, use part number c6z06shocks.
Thank you,
Gene.
Greetings Friends,
C5 base 23.0 19.1
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
2013 C6 Z06 Shocks!
Thank you,
Gene.
