Opinions of MSD plug wires?
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Good quality, but really as short as an ls engines wires are, a wet shoe string would work. In other words any ls wire is good enough so dont believe the hype that a wire is going to gain you horsepower. If you need wires the msd is a good choice. I like them better than the gmpp red wires everybody recommends
I have them and Like them, They have an adjustable plug end so they dont hit my headers. When pulling the old GM ones off I notices how thin and flimsy they were, 2 broke as I was removing them. I ordered the MSD and was really happy with how thick they were and the way that I can adjust them.
I also got them from a forum sales and it went smooth and had them in a few days.
When I built my motor, I put a new set on and the tuner told me I was better off with originals with 32k mi that MSD. Sold them and basically broke even because I also got free plugs. I wouldn't use them.
I tried them all on my C4; had bad experiences with several sets of MSD and found Taylor to be better. I'm using Magnecor on the C5. IMHO they are the best wires available. They're more expensive - you get what you pay for.
Thanks for all the replies. I don't have an issue with the LG's, they have built-in header insulation, but I was also attracted by that wires plus plugs offer. Doug, you've tuned my car so aside from all the other negative replies, I highly regard your opinion. What do you guys use? I don't necessarily need new wires, I just thought I'd consider changing them with that SDPC offer. Maybe all the responses have a contributing factor as to why MSD has filed for bankruptcy.
St. Jude Donor '13
If the lg's are ok i would run them. Currently I have msd's and they're fine. Prrviously I ran the gmpp wires and like the stock factory wires they were ok up until a plug change. I havent found a set that survives a plug change. Even with dielectric grease. Its not the boot but the clip wont come off without ripping off the end of the wire. Mexico is the new China. Next time I'll try the Taylor's myself.
Well another here that had some corrode in only a couple years.Took mine to a reputable shop to get an EBCM problem traced down,when talking to them during the process they informed me I had a miss.The found the cylinder,swapped in an old used stock wire (for free) and the miss was gone. they gave me the old MSD wire and look up the boot,,corrosion! They ran great till then,but no longer a fan.I too am going to the GM Red performance wires.
My car had MSD wires on when I got it. Car developed a miss so one of the things I checked was the resistance on the wires. Found one wire at 6000 ohms all the rest were between 25-27 ohms. I changed them out with another set of MSDs, threw out the bad one and now I have 7 spares.
St. Jude Donor '13
Wait till you see the gmpp wires. I was highly unimpressed.
So we blame corrosion on the wire manufacturer? I guess they could use stainless steel. I thought that was one of the main reasons to slap some dielectric silicone in the boot.
