Dipstick advice for a dipstick!
Old 10-05-2013, 11:44 AM
Fitt's Vette
Fitt's Vette's Avatar
Default Dipstick advice for a dipstick!
Need a new oil dipstick tube and was searching online for the options. I did a LT headers install and could not get my oil dipstick tube to fit and not be in contact with a header tube so I bent/modified it slightly to work. The new routing of the path makes it very difficult to remove the dipstick and reinstall it as only goes back in with the end oriented one way. My second fear is that the new path has changed the reading of the dipstick. SO I was curious if anyone here has used or heard anything about the Lokar Flexible and Machined Engine Dipsticks found at Summit Racing (ED-5008).
(http://www.summitracing.com/parts/lok-ed-5008/overview/)
The flexibility of the tube interests me, but I am concerned that the end of the stick might be close to the crank assembly and would cause me more troubles that it is worth. Any opinions or advice would be appreciated.
Old 10-05-2013, 11:53 AM
Paul 75 L82
Paul 75 L82's Avatar
I had that same one on a Camaro and it worked and looked good.
Old 10-05-2013, 01:28 PM
Fitt's Vette
Paul 75 L82- Thanks for your input I greatly appreciate it! Others opinions/experiences?
Old 10-05-2013, 03:30 PM
DBS99MagRedCoupe
DBS99MagRedCoupe's Avatar
I have the Lokar on my 02 vert. No issues in the past year.
Old 10-05-2013, 04:17 PM
momo20
momo20's Avatar
what brand of LT's did you install? my LG long tubes allowed me to re use my OEM dip stick with no issues at all
Old 10-05-2013, 04:57 PM
MawneeC5
MawneeC5's Avatar
Glad you brought this up, I may have to go this route with my new turbo manifold. As it is I've been running 2000 headers on my 03 with the dipstick all bent around them :P
Old 10-05-2013, 09:44 PM
Fitt's Vette
I used the XSPower LT's, and others have no had troubles reusing the OE dipstick and tube but for some reason I can not get mine back in...so I am going for the alternative.
Old 10-05-2013, 09:45 PM
Fitt's Vette
Great thanks for your time and advice! Is it relatively stable removing the dipstick, IE haven't had issues with the bottom pulling out of the block?
To Dipstick advice for a dipstick!
Quick Reply: Dipstick advice for a dipstick!
