C6 Z06 brakes on C5
C6 Z06 brakes on C5
I jus purchased a full set of c6 z06 brake calipers, basically that comes stock on a c6Z. My question if anyone can help me is do i need stainless steel lines or do the lines that come stock on a c6Z suffice?
Location: Arlington Texas, originally from San Angelo, TX
The C6 brake lines have a different size fitting on the frame-rail side compared to a C5, so you definitely don't want the C6Z lines. Purchase a set of StopTech C5 braided lines from LG Motorsports. They are slightly longer than the OEM C5 lines; making them perfect for the C6Z caliper swap. ZIP also has some braided C5 lines that are the correct length for the conversion.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
For everyday street driving you won't notice a big difference over stock, at least I didn't, but man they look awesome & with the stainless lines and Motul fluid you will have much firmer pedal feel as well.
The research i did suggests that there is an improvement over stock breaks and like the OP said they are going to look really sweet! I cant wait to get them installed. I feel like i got a pretty good deal on them as well
Thoroughly chapped
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Just don't get StopTech P/N's # 950.62003 front/950.62503 rear.....
Ask me how I know....
Thoroughly chapped
NCM Member '09
I had everything I could think of bought and ready....including those brake hoses. When they were flare vs the C5 bubble flare, I had to rush to have a set made, this being Tucson, the biggest small town you'll ever see. Luckily, we've got a D.O.T. approved builder here that whipped me up a set quickly, but it still took a day-which killed me in rack time.
Those are part numbers for the Stoptech C6 brake lines; you're right they won't work (the Stoptech C5 lines will however). I mentioned earlier how the C5 & C6 lines have different frame-rail side ends. I think the OP is getting a bit confused here. Just get yourself a set of the Zip stainless C5 lines found in the link I provided earlier. I have used them numerous times for this conversion.
Thoroughly chapped
NCM Member '09
Yeah don't get me wrong, I love mine & I'm sure you will as well, but the stock c5 brakes have been more than sufficient for street use, but I'm all about change as well, and on a c5 they look awesome
Thoroughly chapped
NCM Member '09
Exactly....I did mine for looks 90%....mostly to fill up the wheel barrel, and to add some color to a plain colored car.
One more question for you guys, what brake fluid did you use? Did you guys have to order online or can i get it at the local parts store?
