Let there be light!
Wow Mike, those seem bright as your headlights. Nice
Supporting Vendor
We offer the Adjure housing and the Cree 80W LED bulbs as both a discounted upgrade to the adjure housing and as a stand-alone product:
http://shop.radioflyerinnovations.co...rvette-013.htm
http://shop.radioflyerinnovations.co...for-C5-046.htm
Received 19,274 Likes
'20-'21-'22-'23-'24
Excellent upgrade for the backup lights. I think this will be my next mod.
Mike, please add me to the list of folks interested in the info on those bulbs. I'm in the same boat as you...dark tint on the back window and always opening my door to check for obstacles back there!
Awesome find!
Awesome find!
St. Jude Donor '13-'14
Ordered mine the day the thread was posted already got mine in.
Thanks again man i am very pleased!!!!
A couple pictures mine were Standard LED replacements to the Ones from the thread.
Comparison
Comparison
#33
I got them off the auction site. Pretty nice bit of kit.
Fitment Type: 1157 (2057)
Color: Cool White 6000K-7000K
Specifications
1.Input(mA):940±50
2.Lumens (lm):800-900 lm
3.Power: 80W = 4pc x 5W CREE Chip
(Top)+12pc x 5W Epistar Chip (Side)
4. LED Quantity:16PCS,Top 4pc CREE
Chip,side 12pc Epistar Chip.
5. Voltage:DC12V-24V
6. Beam Angle:360°
Specifications
1.Input(mA):940±50
6. Beam Angle:360°
Thanks,Matt
#37
Received 1,679 Likes
Very cool... wish I had reverse lights.... lol....
#38
Hi Mike...please PM details on these. Looks promising and I just had a back up light burn out so I'm going to need to be replacing the bulbs soon. These sound and look promising!
#39
St. Jude Donor '13, '15
That looks amazing. How much wattage are the factory bulbs, like 12?
I don't have the adjure plate frame, would an LED bulb in the stock housing be pointless? I would like better output without blowing budget. Still trying to save up and consider LED tails...
#40
I just installed them in the stock housing and they sure look bright. Would they be better in the adjure housing? probably but you can easily swap the lamps to the adjure later if you want.
Forget the reaching up over the exhaust or removing tail lights. The easiest way to get to and install the reverse lamps is to remove the license plate bracket. Remove your license plate, remove 4 T15 torks screws and the whole assembly comes off. Push the lacking tab and twist the sockets. You can now clean and wax/polish behind the plate bracket, install the two new bulbs (hit your lock button on your fob to test) and reinstall everything. Admire your work.
