AC light on
Moderator, Tech Contributor
Received 2,124 Likes
AC light on
My 01 with dual climate control has the AC light on even with 80 degrees set into the controls on a 50 degree day when it's in Auto. I also confirmed that the AC clutch is engaged when this occurs. The defrost is NOT selected either...when I turn the AC light off it kicks the climate control out of auto into manual operation...I read the owners manual front to back on the AC system and can't figure out why this is happening...any help out there anyone ??
Well I'll check when the temp gets to 35-40 degrees when the AC should not be operating...if it still does I have problems !!
It will do it and you Don't have a problem. The system puts the AC on even if it requires heat, as I said it removes the moisture ......you don't have a problem.
If the clutch is working (i.e. it disengages when you switch the A/C off manually), but it stays on all the time otherwise, you may be low on refrigerant and it's not getting to the high-pressure cutoff limit.
Thanks Bill,
Like I said it switches on and off (AC light on and off) when manual mode is selected and I verified this looking at the compressor clutch but always on in auto even if heat is selected I guess I'll check the refrigerant level !!
Guessing from your remark I'd say you probably weren't even born yet or you were busy riding your Stingray.....with a banana seat...LOL !!!...my last GM product was a 1972 Z-28 Camaro... Enough said !!!
Received 19,299 Likes
'20-'21-'22-'23-'24
At least now you know there is nothing wrong with your HVAC unit.
Thanks gentlemen for all your input...thanks again !!
