C5 Z06 brake upgrade
I'm looking to upgrade to the C5 Z06 calipers and had a few questions...
From my understanding, the C5 has the same size rotors as the C5 Z06. So could I use the C5 rotors with the upgrade or do I need the Z06 rotors? What about pads?
Other than having the calipers red, is there that much of an increase in stopping power?
You don't need the calipers. The Z06 calipers are the same exact caliper with red paint on it. Rotors are the same too. The only differences are the paint color and the OEM pads. The increased stopping power of a Z06 is due to the slightly bigger tires, slightly lower curb weight, and slightly more aggressive brake pads.
It's WAY cheaper to buy a can of red paint.
They are the same parts, only different colors. Unless you mean the C6Z06 brakes, that is a different animal.
http://www.duplicolor.com/products/caliperPaint/
Get new blank rotors and some good Stoptech street pads and you will be happy. Rockauto has some goods deals and so does KNS.
http://www.knsbrakes.com/c/car-items...tte+All+Models
Best option for you is http://www.knsbrakes.com/c/car-serie...nce+Brake+Pads
What everyone is saying is don't waste your money buying new calipers! just get a Duplicolor paint kit. take your time doing it so it looks smooth and you will have the same thing for about $20-30 bucks! Either that or remove all 4 calipers and plug the lines on the car, put a bolt and a washer large enough to keep the area where the brake line attaches clean and cover the slides up and have them powder coated locally for like 100 bucks.
Amazon.com: Dupli-Color BCP400 Red Brake Caliper Kit: Automotive
Actually its just pricey and not worth it (performance wise). If someone has a dedicated track car they should not be getting c6 z06 brakes. They sure are pretty though.
Thoroughly chapped
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
I'm very pleased with my C6z swap, and it is a little better, but for the expense? It wasn't worth it dollar vs performance, but yeah, they are awfully pretty, and wheel-filling.
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I did mine...a lot of work! However, stopping is definitely improved in the sense that less peddle effort is required for casual stops, and the pedal is softer yet the braking is greater. However, I installed the stock Grand Sport padlets, which create so much brake dust I want to cry! If you do the job get the better brake pads...some are even 1-piece design, instead of using all those little pads...an extra $225 but worth it unless you like cleaning off greasy brake dust every 20 miles!
To powdercoat, you need to remove the pistons and seals, strip them to bare metal, get all the brake fluid out of the metal (phosphate wash) then reassemble with new seals after coating. Well worth it (especially if you have your own setup like I do ) but it is a lot easier (and cheaper) to use the brush on caliper paint.
Received 1,260 Likes
I got my complete c6z brake setup with stainless lines and 1 piece hawk ceramic pads from kore3 for a lot less than Gene quoted me... and with gmpartshouse the only way to get the pins is to buy GM pads which are a few hundred and a few hundred more if you want a different pad... basically too much money from them and there are better options to buy from... I got everything for $2100 and Tobin (kore3) is great to deal with... tps motorsports puts together a good deal too... I have 19's and honestly just did this for the looks... I don't track my car or put it under stress where I would need a brembo kit or something similar... a front brembo setup will cost more than a full c6z brake setup... also keep in mind that c6z brakes are quite a bit heavier mainly due to the rotors, I want to say around 50 pounds heavier total
NC Events Coordinator
