taking C5 out of storage
Old 01-27-2014, 12:43 PM
wildpalms
4th Gear
wildpalms's Avatar
Default taking C5 out of storage
Had only 2 wks with my 'new' '02 Coupe b4 putting it in storage for winter. Got helpful tips from forum on storage. Is in climate controlled
garage, trickle charger, cover, dryer sheets in interior and engine
compartment, full gas tank w/stabilizer, oil change and new filter.
What is recommended when I finally get her out of storage ?
Freezing in Wisconsin
Old 01-27-2014, 12:52 PM
jrose7004
jrose7004's Avatar
Received 1,675 Likes on 1,298 Posts
Change the oil if you haven't before storage and fire it up and enjoy the car!
Old 01-27-2014, 01:14 PM
Phanni
Phanni's Avatar
Received 1,731 Likes on 847 Posts
When you start it up, let it idle for a minute or two to distribute the oil, then enjoy.
Old 01-27-2014, 04:55 PM
donald4972
Support Corvetteforum!
donald4972's Avatar
St. Jude Donor '14-'15
Check the air pressure in your tires, sometimes they lose a few pounds sitting all winter. Some guys put a piece of carpet under each tire, while it sits in storage.
Enjoy your C5 !
Old 01-27-2014, 06:49 PM
dadaroo
dadaroo's Avatar
Why would you leave the battery in the car on charge while in storage? You must be a gambler.
Take the battery home!
Old 01-27-2014, 10:15 PM
El original
El original's Avatar
Don't forget a quick hug and kiss!!!
Old 01-28-2014, 11:37 AM
Mallett Z
Mallett Z's Avatar
2015 C5 of the Year Finalist
St. Jude Donor '07-'08-'09
Whats wrong with leaving it on a trickle charger?
Old 01-28-2014, 01:08 PM
DevilDog II
DevilDog II's Avatar
Oldtimer
I've stored mine in a climate controlled garage for several years. The only thing I do when I fire it up in the spring is let it warm up for about 5-10 minutes and let some of the air out of the over inflated tires. Since it's usually been sitting for 5 or 6 months, I drive it rather gingerly for a few miles until it's had time to warm up to operating temperature.
Old 01-28-2014, 01:27 PM
Lou64
Lou64's Avatar
Fiberglass + electrical fire = crispy Corvette
Old 01-29-2014, 06:01 AM
oldschoolvette
oldschoolvette's Avatar
Old 01-29-2014, 08:43 AM
dadaroo
dadaroo's Avatar
Nothing, unless it fails and overcharges spilling acid everywhere and on the PCM. Or, it fails and lets the battery drain down too low and shortens it's life. I understand putting a trickle charger on a car that you routinely drive and inspect but if you are not going to drive it for an extended period in storage I would remove it. I assumed your extended storage was not in your garage where you could keep an eye on it.
To taking C5 out of storage
Quick Reply: taking C5 out of storage
