03 magnetice ride control shocks
Dealer indicated I needed to replace magnetic selective ride control shocks. I live in Virginia Beach, VA. Does anyone know a good repair shop in the area?
Just replace them with regular shocks or coilovers and have the mag ride disabled. The mag shocks are very expensive to replace. Theres a write up around here somewhere
I'm one of those weirdos that likes my F55 suspension.
Did your dealer say that all four shocks had to be replaced? If so, what was the reason?
I checked at GMPartsHouse.com and rear MSRC shocks are $634 ea. and front MSRC shocks are $813 ea.
FWIW, there's a reason why Ferrari and Audi licensed the technology from GM and I doubt it's because of inferior ride and handling.
Do all '03's have the mag ride? How do you know if you have it. I have an 03 Z06
How can i check for leakage and how much trouble to install shocks and reset warning? I still would like to get a good shop in virginia beach, va to check it out before I attempt to change the shocks.
The dealer stated all four were leaking. I never notice much difference between sport and tour ride. The car i own has had some major modification with the intake, exhaust and rear end. The car runs great and very fast (not good gas mileage - 23 mph highway). The ride is bumply and now when I hit a bump on the interstate the rear end seem to sway. I have ridden in several C5s with magnetic ride and in tour they were fairly smooth.
If you're simply R&Ring the OEM MSRC shocks, and you have the right tools, (jack, rachet/sockets, etc.) the shocks should not be that difficult to replace. You should also be able to reset the warning in the DIC once you've replaced the shocks.
I found a site that shows how to R&R the shocks.
http://fuzzydiceracing.com/test.htm
If you're looking to replace the OEM MSRC shocks with conventional shocks, you'll need to follow the procedure in post #3 as 8VETTE7 suggests.
Received 19,309 Likes
'20-'21-'22-'23-'24
Don't know how many miles you have on the car, but I would say it is very unusual for all four shocks to be leaking at once. Before I would spend nearly three grand on shocks, I would either install some good regular shocks and tune out the F55 option or install some coilovers as mentioned above.
Thanks everyone. I'm love the MSRC ride, looked for over a year to find Yellow O3 with MSRC. Vette was a daily driver for me. Love it that much. Due to work and snow, I'm having to wait to obtain a second opinion.
MSRC shocks
If you can get under the car you can see leakage on the shock, kind of a greasy look. Just replaced two of mine. They cost about $600 apiece for the fronts and about 450 apiece for the rears. Got them at www.shopchevyparts.com
I personally like my selective magnetic ride control and notice a big difference between touring and sport. Can you tune your coilovers from in the car? Worth the price imho.
On the advice of my dealer I replaced my front shocks. They said one was leaking and time (10 years) more than milage may have been the cause but I replaced both.They matched a forum vendors price so the total was over $1700 installed. I'm suspicious that all 4 of yours could be leaking.
Finding a GM Tech II in San Jose, CA - suggestions?
This sounds like something I'd be comfortable doing myself, but I really don't want to purchase a $400 Tech II just for this. I've not tried the local dealers to see if they'd perform this service, I"m assuming no or very pricey.
Any suggestions, what kind of shops have Tech II other than a Chevy dealer? (in the Denver CO area, now)
The Bilstein Sport Z51 spec shocks with installation, programming out the SRC ($100 for that), and checking for errors was $827.
Trying to figure out what I should spend the $1300 I saved on.
