View Poll Results: which tire for '03 Z
Continental ExtremeContact DW
21
19.63%
Nitto NT05
17
15.89%
Michelin PS2
43
40.19%
Vredestein Sessanta
13
12.15%
Bridgestone Potenza
13
12.15%
Voters: 107. You may not vote on this poll
POLL: Which of these tires for '03 Z
I'm in the market for new rubber for my '03 Z. I understand I have to go to a 275/40/17 on the front to open my choices and keep the 295/35/18 rear. I've been debating back and forth between grip and durability from which I understand you can have one but not the other. I drive my car A LOT in the spring/summer/fall months (6-7000 miles between march-november) so I need somewhat good durability because I don't want to replace tires every year. I also run the drag strip about 5-6 times a year. So I'd like a good cruising street tire with decent longevity that hooks on the drags.
The three tires I've been going back and forth on are the Continental ExtremeContact DW and the Nitto NT05's but from what I gather the Nitto's only last 10k if I'm lucky, and the Michelin PS2 which are practically DOUBLE the price of the others, which is definately a turnoff. Anyone have experience with either one?
I have the DW's on my Vette and PSS on my 05 GTO. Both are very good dry wet and grip. The Michelin's are alot more money though. Road noise very minimal on both.
I went with the Bridgestone Potenza re760 sports on my Z06 and I love them...I did one auto cross day on them and they offered plenty of grip around the track..been very pleased with them so far
The best all-around tire I have ever used is the Vredestein Sessanta. They will satisfy all your parameters at the most reasonable price you will find. Excellent in rain too, if you ever need it.
I was in the same boat as you are. Z06 size wheels so I was limited. I went the Continental ExtremeContact DW's and I'm pleased with them. Only a 3 Season driver here as well and so far no complaints !
Pro Mechanic
the best tire you've used on your Z? what else did you use and how did it compare?
just did some more research on the Conti DW and the rear tire height is 26.1" while the front 275's are 25.7". That's only .4", Will I have issues with TC/AH with these sizes?
should I run a 255/40/17 up front?
