plug wires
Old 02-06-2014, 02:52 PM
hougland
hougland's Avatar
Default plug wires
Time to change plugs and wires, I am going with the a/c delco iridium plugs but not sure on the wires. Any suggestions? It's a stock Vertt with cold air intake.
Old 02-06-2014, 02:58 PM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,836 Likes on 1,799 Posts
The red GMPP plug wires will work perfectly; they're what I have on my car. GMPartsHouse sells them.
Old 02-06-2014, 02:59 PM
slvr bulit
slvr bulit's Avatar
Old 02-06-2014, 03:00 PM
3boystoys
3boystoys's Avatar
Got my wires at NAPA.
Old 02-06-2014, 06:11 PM
92GA
92GA's Avatar
Oldtimer
The stock heat shields will fit the red GMPP plug wires.
Old 02-06-2014, 06:16 PM
Fcar 98
Fcar 98's Avatar
Old 02-06-2014, 06:32 PM
zagger
zagger's Avatar
One more for red GMPP.No benefit to be made by using more expensive wires on a stock motor.
Old 02-06-2014, 07:11 PM
Camjamsdad
Camjamsdad's Avatar
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I'm the only dissenter. I am running the red GMPP wires with the shields. Yes they work but in my opinion they are some of the cheapest looking and feeling wires. They're made in mexico.
Old 02-06-2014, 07:47 PM
Z06ufgrad2002
Z06ufgrad2002's Avatar
I use the Taylor 10.4 mm wires (98003) on my car but there is a case to be made for the Red GMPP wires as well due to the price.
Old 02-07-2014, 10:33 AM
Corvette_Ed
So are approximately 75% of the parts on your car.
Old 02-07-2014, 11:26 AM
BADBIRDCAGE
Support Corvetteforum!
BADBIRDCAGE's Avatar
Received 1,963 Likes on 1,055 Posts
Take a look at the electrical components on your C5. Or you can go to almost any FLAPS and replace all the Mexico manufactured relays on your car from the factory with OH NO!!! brand new relays made in Mexico!
Old 02-07-2014, 11:57 AM
'Shifter
Thoroughly chapped
'Shifter's Avatar
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Did you find them Jimmy?
Old 02-07-2014, 12:23 PM
GoldenFlame
GoldenFlame's Avatar
I went with MSDs for both my LS1 cars. They bend which is great for clearing headers and cost the same as GMPP, $70.
Old 02-07-2014, 02:00 PM
Received 19,186 Likes on 13,910 Posts
'20-'21-'22-'23-'24
That's what I run and they work great.
Old 02-07-2014, 02:08 PM
B747VET
B747VET's Avatar
Ditto
The GM wires that were OE on my car were the cheapest and lousiest wires I've ever seen on any car. As they literally disintegrated while being removed after only eight years and 19K miles, it became obvious that in some things GM takes the term "lowest bidder" to ridiculous depths.
These Red GMPP wires may only be related by familial heritage, but I'd just rather not take any chances.
Old 02-07-2014, 02:22 PM
Corvette_Ed
Originally Posted by B747VET
Ditto
Most spark plug wires will fall apart after eight years. Mileage isn't an accurate measurement. Wires should be replaced at least every five years.
Old 02-07-2014, 02:35 PM
B747VET
B747VET's Avatar
Thank you. But, that point in time just happened to be the moment when I bought the car. And, yes, I've been changing spark plug wires for more years than I even care to remember. Often on cars of friends that were far beyond wire and spark plug change ideal timelines.
That having been said, I've never encountered such cheap lousy wires as the C5 OEM wires. Period. Junk would be a kind descriptor. Are these Red GMPP wires likely much better? Yes. Would I still go there on any of our cars? No.
Just as you decided to lecture on the obvious responsibilities of engine related car care, I was also taught a few things in my racing youth, one of which was, "Never go cheap on plugs, wires, or filters." Penny-wise, pound foolish.
To plug wires
Old 02-07-2014, 03:42 PM
RedZMonte
RedZMonte's Avatar
Stock Delco Irridium plugs with GMPP Red wires with stock heat boots and cant be happier. My tuner also had no problem getting a tach signal with thoes wires.
S
Old 02-07-2014, 07:06 PM
hougland
hougland's Avatar
I think so, I had Cataro store order them for me.
Old 02-07-2014, 07:08 PM
hougland
hougland's Avatar
Thanks everyone for all the advise, we ordered the RED WIRES and will put them on next week.
Quick Reply: plug wires
