flared fenders with stock z06 wheels?
wider wheels would be the safest bet. I've heard horror stories about spacers that fail. mostly on trucks and jeeps, but I would think it holds true for any vehicle.
I know in some states they are not leagal to use on the street and a vehicle will not pass inspection with them on.
besides, the whole reason to flair fenders is so you can have wider tires to get more traction right?
just sayin.....
just sayin.....
Hub adaptors are your best but.. IF you use a spacer, make sure you get a high quailty one that has the EXACT bolt patter and a Centric hub built in and you will NEED longer and stronger studs. ARP makes studs that are longer and hardened to replace the stockers and press in like stock.
http://www.vettemod.com/forum/showthread.php?t=7112
Eibach makes some nice kits.. As does H&R.. sure others out there do as well..
Good Spacer w/ Centeric Hub Ring:
Good wheel daptor (bolt to stock studs and adds new ones):
S
S
