Check engine light
Check engine light
I have a[B] C5 1999 ]that the engine light stays on. Someone says I can do something to the mufflers that will make it go away. The computer says it is related to the exhuast
Received 19,307 Likes
'20-'21-'22-'23-'24
Post up the code from the DIC and surely someone can give you advice on how to fix it.
Hit us up with the number and we will get you straightened out the correct way and the least expensive too!
Thanks,Matt
Thanks,Matt
