30 pin adapter
Old 05-03-2014, 09:53 PM
TexasVette64
TexasVette64's Avatar
Default 30 pin adapter
Last year I bought the 30 pin for my stock radio. You could play Pandora through the head unit while it was in Aux. It plugged to my Iphone 5...well, I no longer have the Iphone 5 and now have the Samsung S4. I'm looking for the female adapter that will reduce to a micro and plug into the Samsung. The only thing I can find is ones that does DATA and charging. Any ideas out there? Thanks for taking the time.
Old 05-04-2014, 02:36 AM
avigar
avigar's Avatar
Unlike the old Iphone's 30-pin connector, you can't use the S4's micro USB power connector to output your audio. You'll need to change the adapter/connector to the standard 1/8" headphone plug type connection. This will then connect to the headphone output of your S4 phone.
Old 05-04-2014, 02:48 AM
avigar
avigar's Avatar
I believe this is the new kit you'll need to play your audio from your S4 phone. It's available from one of our supporting vendors, DD Mods.
http://shop.doubledmods.com/ZUNE-C5-...HGM4-pxdx4.htm
Another option to explore is to add a 30-pin BT receiver to your current setup. In theory, this should allow you to connect wireless, via BT, from your S4.
http://aluratek.com/30-pin-bluetooth-audio-receiver
Old 05-04-2014, 12:56 PM
CactusCat
CactusCat's Avatar
Avigar, well answered. Thanks!!
Old 05-04-2014, 02:28 PM
avigar
avigar's Avatar
Old 05-04-2014, 07:59 PM
TexasVette64
I will try this thanks for taking the time!
To 30 pin adapter
Quick Reply: 30 pin adapter
