Failed Emissions - OBDII "Not Ready"
Arizona Emission Test, 2002 C5. The OBDII System is "Not Ready" as reported by the vehicle's on-board computer.
Does anyone know what this means? I had the battery out for a few days while installing an MP3 player. Is it possible the sensors got reset somehow and have to reacquire info?
GENERAL MOTORS (SPECIFIC) OBD II DRIVE CYCLE
Performing a GM OBDII Driving cycle:
1. Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 122°F (50°C) and within 11°F (6°C) of the ambient air temperature at startup.
Do not leave the key in prior to the cold start or the heated oxygen sensor diagnostic may not run.
2. Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire, and - if closed loop is achieved- Fuel Trim.
3. Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 55mph (88km/hr) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4. Hold Steady Speed. Hold a steady speed of 55mph (88km/hr) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5. Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 20 mph (32km/hr). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6. Accelerate. Accelerate at 3/4 throttle until 55-60mph (88-96 km/hr). This will perform the same diagnostics as in step 3.
7. Hold Steady Speed. Hold a steady speed of 55mph (88km/hr) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8. Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
If the battery is disconnected you will have to go through a full drive cycle. Just drive it a little more and if it keeps happening you may have a grounding issue.
Thanks for all the replies. I had the battery out for two days, finished installing the MP3 player and then drove 15 miles to the inspection station so I think that is probably the issue.
http://www.actron.com/product_detail.php?pid=16366
Or
http://www.obdii.com/drivecycle.html
Toque
I agree, just drive it every day for a week, you will be fine. I think following step 5 on that GM cycle stuff is dangerous so I didnt even follow the steps. I just drove it every day bringing the temps to operating range each time.
Good luck.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
In the C5 it would take approx 100 miles. Stop, turn engine off few times, and it will pass SMOG.
This happened to me back in November when I bought my Z06, it needed a battery, and needless to say the OBD test failed. Tried 70 miles, and failed drove and extra 30, and passed.
