What type of rotor for my application?
It's that time to replace pads and rotors. My C5 is mostly garaged, but I enjoy getting on it and taking it to the track to drag at times. With that being said I've heard drilled brakes may look good for the bling, but may crack as well. What are your thoughts on brakeperformance.com's rotors? Should I purchase Cross-Drilled and Slotted Brake Rotors, Premium Dimpled and Slotted Brake Rotors, or Slotted only Brake Rotors? My C5 is black with chrome z06 rims, should I go with the zinc coated rotors that have the black slots and hat or the silver slots and hat? I will be pairing them with Hawk HPS pads.
Received 19,274 Likes
'20-'21-'22-'23-'24
I'd go with the slotted only rotors with the zinc coating.
The C7 has slotted-only rotors.
The Viper has slotted-only rotors.
ALMS GT Race cars:
Corvette C6R: slotted-only
Ferrari F430GTC: slotted-only
Jaguar XKR GT: slotted-only
Porsche 911 GT3 RSR: slotted-only
So, yes, slotted-only is the way to go. Now, the most popular slot type is the J-hook b AP Racing. However, there are a few other rotors that cost less and have somewhat similar slots, such as the Hawk Quiet Slot design:
I'm sure they'd pair well with their own pads.
ALMS GT Race cars:
decent blanks. the hps is a pretty mild pad, great DD pad really, low dust, decent cold bite and no noise. with that pad there's no measurable benefit to a slotted rotor besides those people who think they look cooler
blanks are 40 a rotor, guys spend 5x that on cosmetic rotors here
i don't get it personally
centric has a high carbon iron rotor you can get fairly inexpensive shipped off amazon, stoptech also makes a high quality blank
I like think the stockers do good for my daily driver, but racing I would go for a carbon ceramic type of breaking system. I guess in the end, what do you want to do and where do you want to go. A run down the interstate or even a daily, stockers are perfect. Race circuit would be full stainless lines, coupled with rotors, pads, and calipers that would cost more than my car.
full carbon ceramic is expensive ! i've never even seen them on anything besides the c5-r
usually guys use $30 rotors and pads like the hawk DTC line if they go racing. they don't even really work until 300-400deg and up. absolute destroy rotors too, hence the $30 rotors, you destroy any rotor with a pad that aggressive. they also vaporize the booties on stock calipers. pads are spendy though, just under 300 for the fronts alone
you know something i just ran across? the c6z calipers and the c5 calipers have similar clamping force. the c6z is more modulated and stiffer but overall force is really similar. that surprised me
as for this thread, the only cosmetic perk i could see paying for is the zinc plating. on a street car that gets rarely driven it would be nice to keep the rust down
Amazing that the clamping force is the same, well similar. I guess what sets them apart would be how much abuse the c6z can take over c5 stockers?
The benefits I've seen and experienced are:
1. Faster initial "bite" with less pedal travel
2. Pads stay parallel to the rotors
3. Glazing due to infrequent use is not an issue
Hawk is the company that makes and recommends their quiet Slot rotors. Apparently, their HPS and Quiet Slots DO go well together - just call Hawk and ask them.
you don't say?
i'm not even going to ask how you believe slots make the pad say parallel to the rotor, or what exactly that even means. multi piston calipers almost never have uneven wear issues if that's what you mean
this is literally the ONLY car forum i visit where people are hung up on bling rotors. evo forum, honda tech, we're all on blanks, cheap and throw aways. if you want more bite, use a higher friction co efficent pad, the hp+ perhaps, or, one of my all time favorite street pads ever, the ferodo ds2500, the MU on the new ds2500 is close to .43-.50 depending, the hps isn't even .40 if i remember right. hawk also released an updated pad called the 5.0 which looks pretty cool on paper, higher MU than the hps, but without the dust or noise of the hp+, they are something like .42 or .43, no idea if that climbs as they warm up
the only thing i've found slotted rotors to be useful for is with pads that glaze easily, well, that and they seem to dust more and last fewer miles, likely because of that sweeping motion on the pad...which is why they are great for pads that glaze easily
Uh, I think I have some experience, here. I've been designing and testing rotors for years - slotted, drilled, blank, cast iron, stainless steel (hardened to Rc 40), and of course, lots of pads, including sintered metal.
Even if you don't believe my own experience, seeing all those stock and racing cars with slotted-only rotors, you STILL believe they are bling only? Give AP Racing a call and see if they believe YOUR theory.
For a street car just get centric premium rotors with stoptech street performance pads. $300 for all 4 corners from forum vendor KNS, done.
http://www.knsbrakes.com/c/car-serie...nce+Brake+Pads
there's a reason nearly everyone at your local SCCA meets is on blanks. the braking performance is all in the pad and these are street cars
what works in autocross is vastly more important than what works on a high speed track car when it comes to a street setup
there's a host of solid information on the web about this sort of thing if you cared to look for it rather than just follow the marketing arm of the people pushing these expensive rotors
http://automotivethinker.com/brakes-...d-and-warping/
to start
along with countless threads on forums where people actual care about performance {which isn't here}
i mean, if you want to spend more because you think it looks cool, that's one thing, but street pads don't gas and usually don't glaze. if you had some that did, slotted make sense but you also get more dust and a shorter pad life
in my mind, if i wanted a higher MU on a street car, i'd just get rid of the hps and use the hp+, even their new 5.0 is a has a few points more on the friction mu scale and doesn't have any of the drawbacks of the hp+. on the fronts you would have hps $100, expensive rotors $300-400, OR, 5.0 pads $135, delco durastop rotors $80, that's 400-500 vs 215 and the 215 combo at least has a measurable rise in MU rather than a "i think the slots are increasing my initial friction" feeling
as for the part about you work for and design rotors or whatever else. i don't play the old people internet credibility game. if your argument doesn't support itself i really don't care if you're einstein incarnate
I have plain blanks sitting in my kitchen atm. I got all 4 for around $100 using some coupon codes and shopping for deals. I can just replace them every track weekend without thinking about it for that kind of money.
I tend to leave them to their sillyness as I use mine as a fun commuter. If nothing else those boards make me laugh at least once a day.
HAHA! my other car is a fiesta ST, not only do all those guys think they are driving straight up race cars. They also feel that slotted and drilled is the only way to go.
So according to you guys....
NO ONE should ever pay more than the price of GM shocks for coilovers for the street
NO ONE should ever buy a catch can, since our cars didn't have them from the factory.
NO ONE should ever install a CAI setup, since you won't gain anything when street-driving.
You can post all you want about how none of these products make any difference, but there are thousands of CF members who can prove you wrong - sorry to burst your bubble.
By the way, the slots in my PowerSlot rotors do NOT fill up with brake dust. I am running the OEM pads, which are very good in their own right.
