Ramps and Jacks
Ramps and Jacks
had my vette for a little over a year and considering some ramps so that I can do some of my own maintenance... problem is I am a little uneasy getting under the car. After researching I ran across race ramps and for some reason I feel the ramps would be a safer option than jack stands.
So my question is anyone here using race ramps?? Opinons? I know they cost more but considering I have 3000 lbs above me if they are truly better/safer I don't mind spending the extra to get them. Also Ive read where they don't slip when pulling the car up and down the ramp which is a big deal to me as well.
I also know when doing an oil change I would need to jack up the rear.. Am wondering what the recommend jack is? I found a low profile Michelin jack at Sams club for $99 but it didnt get great reviews. Thanks Everyone.
Dan
Dan
1st Gear
Race Ramps
Dan
Dan
Received 1,090 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Dan - There are plenty of threads on jacks, ramps and all that. Search a little and you will read for a week!
Harbor Freight has a 1 1/2 ton jack on sale every so often for $59.99 that is the darling of the forum.
Race Ramps too, are incredibly popular in unbelievably lightweight.
Many have made ramps out of 2 x 10's.
I ended up with a used Kwik-Lift. Awesome toy to have as it make working on all our cars easier!!
Additionally, it was my brides peace of mind as she didn't care for the wood ramps. I guess she wants to keep me around!
Good Luck!!
Good Luck!!
Build your own stair ramps out of 2x10 wood. My buddy trayed out his ceiling and I took the 2x10's I constructed them 7ft long and every bored stacked and nailed was 1ft shorter to 2ft an it lands on a bolster so I can pull the ramps out. Then I can just jack up the rear off the cradle with a 2x4
As stated, race ramps are highly regarded by many. Cost?
I built my own out of 2 x 10's, similar to pictured above.
When under the car, I always have it on jack stands. Also I always have the jack in place. Also, I always have at least one set of my ramps under the car not far from me. If something failed, or even earthquake or ( who knows what ), the car will not fall on me, but on the ramps.
Even when your car is on jack stands, you can stack your 2x 10 ramps under the tires, just a little less than what height your jack stands reach is.
I like redundant saftey, not just the jack stands. As I think your concern is.
Be safe, even if a little slower that way.
Don
Don
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Good Luck!!
Good Luck!!
Currently on sale for $59.99 until June 10. Item is 68053 and coupon code is 86741863
Received 3,054 Likes
I have a set of 57" 2-piece Race Ramps and a pair of Trax Jax. The ramps are extremely light weight and non-skid. They make changing the oil and any maintenance task safe and easy.
To lift the rear from under the cradle I have a Larin 2-ton aluminum low profile jack. I purchased it over 9 years ago and it still works well. I also had 2 Harbor Freight 1.5-ton aluminum low profile jacks that each started leaking after 5-7 years and are both gone.
I have installed frame rails with built-in jack pads from Elite Engineering that can be used for lifting from the sides but I also use them to position jack stands under the pads in case of jack failure while I am underneath.
http://www.dsgperformance.com/Race-R...ribs-Universal
I have these. It takes some stones to raise the car that high to get the cradle under the wheels, but they are pretty badass..
Good Luck!!
Good Luck!!
Former Vendor
Race Ramps Father's Day Special
Get a free upgrade to the Heavy Duty version of the service ramps, or choose one free Reverse Logic chassis specific jack pad tool. The service ramps also qualify for a free pair of Race Ramps wheel chocks with mail-in factory rebate which expires on 30-jun-2014. Father's Day offer good 2-Jun-2014 through 15-Jun-2014.
http://www.reverselogic.us/constant-incline-ramps
Eligible ramps:
RR-56-2 - $205.20
RR-XT-2 - $300.60
RLL-72-2 - $306.00
RLL-78-2 - $387.00
RLL-87-2 - $405.00
All prices above include free shipping and a choice of free upgrade to Heavy Duty 5000 (per pair) capacity ramps OR free jack pad tool.
Eligible ramps:
RR-56-2 - $205.20
RR-XT-2 - $300.60
RLL-72-2 - $306.00
RLL-78-2 - $387.00
RLL-87-2 - $405.00
ramps
Here is a link to an article by Mike Mercury on building a set of ramps.
http://www.tim-yvonne.com/mikemercury/ramp.htm
orca13 (04-03-2019)
Received 4,713 Likes
Just buy a set of race ramps, they make a number of sizes...your life is at stake here
