Service Traction Contol / ABS Light
Last night I drove through a rough patch of road, and my service traction control and ABS lights came on immediately. I shut the car off and restarted - no luck. Left he car sit overnight with the battery disconnected and this morning is seemed normal - or so I thought... Took a quick drive to the bank, when I came back out the lights were back on.
Any ideas what this is or how to fix? This is a 2001 with 17k miles.
Thanks for any assistance.
You need to pull up your codes and post them and then someone will chime in and help you.Post all the H,C,HC codes.Sorry I can't help you.Whoops ,8VETTE7 we posted at the same time.
Fred
Fred
Thanks for the quick response!
I pulled the codes and found:
28TCS C1214 HC
AO-LDCM B2282H
B2284H
U1064H
A1-RDCM B2283 H
B2285H
U1064H
Did a look up and found these are Column Lock Open or short to ground? and door control modules?
Any idea how to fix these?
Appreciate the help.
28TCS C1214 HC
AO-LDCM B2282H
B2284H
U1064H
A1-RDCM B2283 H
B2285H
U1064H
The U1064 code was probably due to dis-connecting the battery
