Home-made low profile ramps
I was having issues getting the car up onto the ramps I bought now that it's lowered, so I decided to make my own. Four ramps total, two front and two rear. Measured so neither the rear nor the front scraped one bit. Worked like a charm.
Is that about 6 to 8 inch spacing on front boards? I have been thinking about doing the same thing for awhile. I believe I would like to get a couple inches higher.
Very nice DIY! I too like the stops you have there. I made some a while back with 2x12's but I need to add some of that Anti slip stuff (the mat stuff you put under a rug) on the bottoms to keep them from sliding on my garage floor when I go to pull the car up. You should post up the dimensions of yours heck of a lot cheaper than race ramps!
Received 1,674 Likes
Looks like they get the job done.
Former Vendor
Not a week goes by where I don't hear from a customer wanting to upgrade their heavy wooden ramps to lightweight Race Ramps which are normally much higher than the wooden ramps. Usually the reason is that they are tired of lugging around the weight, especially in the case of trailer ramps.
Yesterday, I heard from a customer with a completely different motivation for retiring the wooden ramps. After years of leaning the wooden ramps against the garage wall, the customer is worried that his young grandson will knock the ramps over and get crushed by the weight.
Race Ramps make over 60 different ramp models and Reverse Logic offers an additional dozen custom extended length or extra tall ramps. It's possible to make wooden versions of some of the smaller Race Ramps, but, it's not practical to make the larger ramps from wood.
A wooden version of our RLL-78-2 ramp (78" L x 14" W x 12" high) would weigh about 130 pounds. And that's just for one! It's true that Race Ramps are not inexpensive. But they are very safe to use and you won't break your back lifting them.
Don't get me wrong I would LOVE a set of race ramps especially if i used ramps on regular basis then I would definitely buy a set. However I've only used my diy ramps twice in the last 6 months. I'm also one of those that like building my own stuff. Sometimes even when it makes no financial sense whatever to diy I still have a very hard time not doing the diy thing.
The wheel chocks were actually given to me by a buddy with the simple jack you see pictured under the rear. Not sure of the actual brand off the top of my head, but I found these that are either the exact same brand or close enough:
I really like my race ramps. I have wasted a lot more money than what these cost on other
stuff I shouldn't have bought. But, you insist on making your own heavy wood ramps, at least cut the leading edge at a 45 degree angle, make the rear section removable, and put in a stop just made out of a 2 x 2. You could also make them progressive by staggering the
lengths. Always costs a little more for something better, faster, and lighter.
