Weird Day
Weird Day
I had a rough Corvette day.
1. Latch for glove box broken, looks like an easy fix. I ned to remove key cylinder from plastic molding.
2. After I removed the glovebox latch, my horn started blowing. Though I hit panic button while fooling around with glove latch, nope!.
Remove battery power to stop horn.
Any clues for horn issue?
It might be related to the car's security system. I'm completely guessing here but maybe because you can lock the glove box it is alarmed too, and disconnecting it cause the alarm to go off
Well,I did a little Google research and it could possibly be the horn membrane under steering wheel, relay would be my guess.
I bet that relay is behind center dash where hazard relay is located, or some where in that area. Hazard relay is problematic too, so might take care of both relays, Hazard and Horn.
Received 19,283 Likes
'20-'21-'22-'23-'24
Hope you get it fixed and it doesn't require a lot of tear down to figure it out.
But I agree now that I think about it, its probably the horn membrane under the steering wheel. I think it normally fails closed (horn on), while the relay probably normally fails open (horn not functioning).
