Check engine light on & other codes
Old 07-06-2014, 07:16 AM
703's Avatar
Default Check engine light on & other codes
Ran the codes and this is what I got. Anyone know what would be causing them and how to fix it.
PCM
P1111 H C - Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P0113 H C Intake Air Temp (IAT) Sensor Circuit High Voltage
I'm also having issues with the drivers side door not unlocking when I use the key fob or after the ignition is turned off.
All codes below are followed by a H
AO-LDCM
B2252 Key Cylinder Switch Fault
B2208 Right Window Down Switch Fault
B2282 Battery #1 Fault
B2284 Battery #2 Fault
U1064 Loss of Communications with BCM
A1-RDCM
B2203 Right Window Up Switch Fault
B2283 Battery #1 Fault
B2285 Battery #2 Fault
B2265 Horizontal Position Sensor Fault
Old 07-06-2014, 11:36 AM
Bill Vett
Bill Vett's Avatar
Open drivers door, pull the accordian tube from the a pillar and the door, fish out the bundle of wires from inside the a pillar, unplug clean contacts, plug back in. Now do the same with the bundle in the door. Replace accordian tube. Clear all codes. Drive a few miles and se what codes come back
Old 07-06-2014, 12:40 PM
rustyguns
rustyguns's Avatar
To Check engine light on & other codes
Quick Reply: Check engine light on & other codes
