DBA & Hawk Complete Brake Packages from $525 Shipped PLUS EXTRA Coupon- Limited Time!
Former Vendor
Looking for the BEST OEM size replacement brakes for your C6 Corvette?
Check out these awesome deals on DBA Rotors and Hawk Pads!
First the discounts-
For a limited time, we are offering an extra 5% off our already super low website prices! This applies to DBA rotors & DBA plus Hawk Build Your Own Brake Packages! Simply enter coupon code dba2014 at checkout. Your order must be over $200 to apply!
All Hawk/DBA SHIPS FREE!
For the best value, buy one of our DBA/Hawk Build Your Own Brake Packages which include a complete front and rear set of pads and rotors from as low as $525.00 Shipped!
Hawk/DBA Packages-
C5 Corvette Base & Z06- http://marylandspeed.com/build-your-...wk-p-5464.html
C6 Corvette Base- http://marylandspeed.com/build-your-...wk-p-5775.html
C6 Corvette with Z51 package- http://marylandspeed.com/build-your-...wk-p-5787.html
C6 Corvette with Z06 & Grand Sport Package- http://marylandspeed.com/build-your-...wk-p-5788.html
Want individual parts instead of packages? Check out our Model Specific brake sections at the links below!
C6 Corvette Brake Section- http://marylandspeed.com/braking-com...c-148_663.html
C5 Corvette Brake Section- http://marylandspeed.com/brake-components-c-62_418.html
About the Parts-
DBA brake rotors are known as the highest quality OEM sized replacement rotors you can buy. They last longer, and resist warping, much better than the Chinese manufactured competition.
All DBA rotors come in two flavors, Standard Series, and 4000 Series. Each of these can be purchased as slotted, or drilled and slotted.
Standard Series is mostly for street use, with occasional track use. Better than 90% of what is on the market, they will work fine for your standard driver.
4000 Series is a rotor that is just as happy on the track as the street. It features a more advanced alloy, and thermal construction. Additionally, each rotor comes with heat strips that change color when certain temperatures are reached to show you how hot to rotors have gotten.
We offer this with Hawk Pads as a package to save you money!
Hawk HPS pads are a Ferro Carbon compound similar to stock, but with better fade resistance. These pads will have the same noise and dust profile as your stock pads.
Hawk Performance Ceramic pads are a ceramic based compound that hit’s the sweet spot for most drivers. They perform basically the same as HPS, but have greatly reduced noise and dust compared to stock.
Hawk HP Plus is a true race pad with great fad resistance. You can use them on a street car, but they will be very noisy and dusty.
C6 Z06 Hawk Brake Pads also have an option for an OEM style padlet design, or an upgraded, better performing one piece design!
Russell Brake Lines take some mush out your brakes with these preassembled 50 State Legal stainless steel brake line kits from Russell. These kits are a great way to improve the braking feel and performance of your Corvette without spending a lot of money
Hawk/DBA Packages-
About the Parts-
Former Vendor
Check out the Holiday Sale we are running on our website at the link below!
http://marylandspeed.com/holiday-i-21.html
If you have any questions, give us a call at 443-730-9428.
