Abs light
Abs light
Have a problem with ABS/TRACTION CONTROL light on . Pulled codes and found # 1228 and #1235 Both stating RR wiring and speed sensor. changed the sensor ...no help, need help with checking wiring, ideas and maybe a pinout of abs connector.
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Maybe you have the dreaded brake module problem. Common problem.
If your car is 2001 and newer it can be rebuilt on the cheap. If your car is older than that, then get ready to shell out some bucks.
Abs
Had that problem with my 99. Found suggestion on forum to engage the ABS (Stop hard on rough or slippery surface several times). Pistons in ABS can stick if not used often.This cleared problem , been a year. Had tried cleaning grounds, etc.
Hope this works for you.
