Are the top of LS1 and LS2 injectors the same?
Old 07-29-2014, 11:43 PM
anykeys
anykeys's Avatar
Default Are the top of LS1 and LS2 injectors the same?
I know the LS1 and LS2 injectors are different but I'm curious if the top of the injector where it plugs into the fuel rail is the same for both.
By that I mean would an LS1 injector correctly fit into an LS2 fuel rail and vice versa without going into the other differences in the injectors? In other words is the same size o-ring used on the top of both injectors?
Old 07-30-2014, 01:18 AM
momo20
momo20's Avatar
did a quick search as I was also curious here is what I found read post #3
http://www.ls1gto.com/forums/showthread.php?t=324708
Quick Reply: Are the top of LS1 and LS2 injectors the same?
