Invisicord Help
08-23-2014, 03:46 PM
Invisicord Help
I can't remember which wires to tap on my 02 Z06 mirror for Invisicord? Any help or pictures would be greatly appreciated...
08-23-2014, 03:52 PM
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Quote:
Originally Posted by
bartsky
Just use a test light, That is what I did. Find a power that comes on with the key.
08-23-2014, 04:32 PM
Thanks! Was brown positive, and black ground...
08-24-2014, 02:16 PM
That bad thing tapping into the mirror is that the radar detector with turn off when your door is opened.
08-24-2014, 02:20 PM
Shylor
I just went out and checked that. My radar is still on with the door open.
08-24-2014, 02:24 PM
Shylor
Mine don't.
08-24-2014, 02:30 PM
Mr.Bill
Mine don't.
You used invisicord Bill? I tapped into black and brown wires.
08-24-2014, 02:31 PM
I wonder if I tapped into the wrong place on my mirror, because my radar detector shuts off until the door is closed.
08-24-2014, 02:38 PM
Shylor
Is your mirror auto dimming? I can't remember if there is a difference or not?
08-24-2014, 02:40 PM
bartsky
Yes.
08-24-2014, 02:42 PM
Shylor
Yes.
I would check to see what color wires you tapped.
08-24-2014, 03:15 PM
Shylor
In any case who drives around with the door open? Unless a mustang blows it off.
08-24-2014, 03:24 PM
Mr.Bill
Ha!! I was wondering the same thing...
08-24-2014, 03:42 PM
Mr.Bill
Obviously no one, but it's annoying to park with the motor running and get out for a second, then get back in close the door and have the radar detector go through its startup process each time.
08-24-2014, 03:43 PM
Shylor
Ah that is true! Did you check to see what color wires you tapped?
08-24-2014, 05:25 PM
After looking at it, I'm connected to the brown (last wire on the left) and first orange wire (second wire from the right). Does it matter that my mirror is auto dimming?
According to the Invisicord site, I have tapped into the correct spots. But there is some discrepancy over where the black invisicord wire should be tapped into if you have auto dimming mirrors. One person said it worked for them if the black invisicord wire was tapped into the black mirror wire.
08-24-2014, 05:38 PM
The 2 orange are 12 volt, I believe you want the brown for switched 12 volt and the black for ground.
08-24-2014, 05:45 PM
08-24-2014, 05:51 PM
Mr.Bill
You are lucky you haven't blown up your unit by letting 12 volts through the ground line.
Yet those are the wires the invisicord web page says to connect to. However it says "Orange (2nd in) OR black (see notes)", but doesn't explain why one over the other. Kind of like, if one doesn't work then try the other.
