Fuel pump whining
Fuel pump whining
I have a 2004 coupe. In the last couple of days I hear a medium pitch whining or humming sound from the back end. Also noticeable in the cabin. It's a steady sound, whether idling or running. Radio and fan is off. Could this be coming from the fuel pump? Is the pump within the tank itself?
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It is most likely the fuel pump you are hearing, Yes the pumps are in the tanks. Does it only do it when the tanks are low?
I also notice this on my 03. It's noticeable when the tanks are low. There have been several discussions on this in the past. It does not appear to be a problem. Some have had the pumps changed only to have the same whine. Expensive also.
Tony S45 (09-11-2016)
