Are longer wheel bolts needed for 4mm spacers?
Old 09-02-2014, 12:54 PM
MSG C5
Support Corvetteforum!
MSG C5's Avatar
Received 2,681 Likes on 1,482 Posts
2018 C5 of Year Finalist
Default Are longer wheel bolts needed for 4mm spacers?
I'm about to start my brake upgrade project. I have a full set of Baer Eradispeed +2 rotors on order with new OEM AC Delco semi-metallic pads and Russell Braided brake lines.
I am running a set of 19" CCW 505As and after talking with John, he sent me two 4MM spacers for the back wheels. I know that Toque and some others on the forum have grinded down their calipers in order to fit the CCW 3-inch lip wheels over the bigger rear brake kit, however I thought I would try spacers first and if I change my mind, I can always grind down the calipers over the winter.
The 4MM spacers are about the size of 3 CDs stacked on top of each other so they are not very thick, just enough for the wheels to clear the +2 roters that will push the calipers further out.
I appreciate any feedback on whether I need any longer wheel bolts.
Thanks!
Old 09-02-2014, 01:06 PM
troyguitar
troyguitar's Avatar
I have 1/4" (6.35mm) spacers on my car with stock studs, 4mm will be fine.
That being said, I wish there were ARP studs the same length as stock but threaded all the way to the end. That would be the ideal setup IMO.
Old 09-02-2014, 01:09 PM
MSG C5
MSG C5's Avatar
Thanks. What wheel/brake kit combo are you running?
Old 09-02-2014, 01:18 PM
troyguitar
troyguitar's Avatar
Cray/TSW Brickyard 19x11 +73mm with 305/30/19 Bridgestone RE-11's over C6 Z51 brakes. I need the spacers because of the big offset of the wheels though - the tires might rub the inner fenders when hitting bumps. I have miles of space around the brakes and brake ducts. The spacers also push the tires out almost perfectly flush with the fenders.
Old 09-02-2014, 01:21 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
I agree with the others. You're good up to 5 mm. After that, longer studs.
Old 09-02-2014, 02:00 PM
Patches
Patches's Avatar
I don't know, Al - I'm thinkin' these 1.75-inchers MotoJB is selling are just the ticket to give you that "rad-ride" look . . .
Old 09-02-2014, 03:00 PM
MSG C5
MSG C5's Avatar
I could then run with the donut tire jeeps that our popular around these parts!
Old 09-02-2014, 03:39 PM
mrr23
mrr23's Avatar
St. Jude Donor '15
You can do what I did when I put 5/16 spacers on my car. I used what is called et lugs. They have the acorn or tapered seat with an extension to go through the rim by about 1/4".
Old 09-02-2014, 07:55 PM
LoneStarFRC
Those will go with joo chain steering wheel, esé.
To Are longer wheel bolts needed for 4mm spacers?
Quick Reply: Are longer wheel bolts needed for 4mm spacers?
