LMC5 Gremlins
LMC5 Gremlins
Just installed the LMC5 about 2 weeks ago as a preventive measure. Prior to install I had no problems with Service Column Lock or Remove Key - 10 sec alarms. Today I started the car and twice got the Remove Key - Wait 10 seconds and the fuel appeared to cut off as the car stalled. Pulled out the key - waited a few seconds and restarted with no problems. The car had been started several times prior to this afternoon with no issues so now I'm really puzzled. Is it time for a call to Compliance?
Received 19,303 Likes
'20-'21-'22-'23-'24
They will take care of you.
Just a thought.....Did you install the brown wire then cut the other brown wire loop? The instructions are on the second page of the LMC5 install manual.
It could be worse...
I get the random "pull key, wait 10 seconds" thing too. Never had it before the LMC5. Sounds like I probably need to do the brown wire thing as well.
What year is yours?
What year is yours?
I had an issue and it was my install. I assumed I needed to do the brown wire (I didn't, but it isn't an issue that I did) as well after the initial install, so I did only to still have the issue.
I called Richard and he walked me through step by step, found where I put the wire in the wrong hole (mine had a space since I don't have a vert and I put the wrong wire in the wrong hole ) and got me rolling.
I wish there were more products I could buy from Richard. He was awesome and didn't even make me feel stupid.
I had the same problem, recently posted about it in another thread. The brown wire fix fixed it for me (so far). According to Richard, this affects about 1 in 200 C5's and there should be no more issues.
And according to Richard I didn't do any harm with my wiring or doing the brown wire even though it may not have been needed.
i put the lmc5 on my 99 c5. still got the pull key and wait 10 sec. i called compliance they sent me the five wire lmc5. and i still have the same problem. it don't do it all the time. what is the brown wire yall are talking about. i would like to try this on my car.
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
If you have questions, call Richard at Compliance Parts.
I had no idea there was a 5 wire LMC5 but I see that you are still having issues. Mine is perfectly fine other than the annoying message. Crazy stuff indeed. lolz
I installed my LMC5 several months ago and I keep getting the annoying pull key wait 10 secs also. I only did it as a preventative measure. However, when I had my car tuned I had the fuel cut off limit raised so I would never have to worry about that issue.
