Unbeatable Prices on Mcleod Clutches @ Hinson Motorsports
Former Vendor
-Lighter than stock pedal feel
-Bolts to stock factory flat flywheels (LS1/LS6 only)
-Easy Installation
-Organic & Metallic disc facing available for smooth & even engagement
-Smooth engagement with excellent release qualities
-Low Rotating Mass (moment of inertia) for quick revs
-Includes CNC machined and anodized flywheel adapter ring
-Blanchard ground floater with multiple straps to reduce noise for streetability
Balancing of you clutch and flywheel together to reduce vibrations is also available
McLeod RST Street Twin Disc 800HP <- CLICK HERE FOR PRICING
McLeod RXT Street Twin Disc 1000HP <- CLICK HERE FOR PRICING
McLeod Street Twin Disc & Flywheel 1200HP <- CLICK HERE FOR PRICING
* Comes with ARP Pressure Plate Bolts
Mcleod Billet Aluminum Lightweight Flywheel 14LBS <- CLICK HERE FOR PRICING
McLeod Billet Steel Flywheel 24LBS <- CLICK HERE FOR PRICING
Don't Forget your ARP Flywheel Bolts Or Your ARP Pressure Plate Bolts <- CLICK HERE FOR PRICING
HINSON Motorsports is a full line distributor of McLeod products. Use the "Search" function on our website to find 1,000's of McLeod products at www.HinsonSuperCars.com.
Former Vendor
Don't forget about replacing your Slave Cylinder. Hinson Motorsports has our GM Salve Cylinders On Sale Now to partner with your new clutch.
Former Vendor
Former Vendor
Just got ANOTHER HUGE SHIPMENT. Whos getting a clutch this go around? You WILL NOT find a better deal on any Mcleod Clutch, we guarantee it!
Former Vendor
Check out our A&A Supercharger build thread with install pics of a McLeaod RST. Updates daily.
A&A Supercharge Link w/ McLeod install pics and tons of other install pics CLICK HERE.
2003 Z06 Project Starts with Base Dyno Numbers 100% Stock Z06
Former Vendor
Get the clutch we trust the most at prices that cannot be matched anywhere. In stock and ready to ship while supplies last. See our website for special promotional prices.
