How common are EBCM failures?
I've been reading about EBCM failures and the lack of replacements for pre 2000 C5s.
I'm not trying to beat a dead horse complaining about the situation, just wondering how common are the failures?
The EBCM in my 98 convertible still works. I also have a 97 Tahoe, which from what I've read has a suspect EBCM. It also still works.
I guess if it fails, I'll just live without it. The Tahoe was my first car with ABS, I drove for a lot of years before it became standard equipment.
It's difficult to predict any sort of time or period that EBCM failure may occur because it's not 100% influenced by just general wear rate. Like with most all electronics environmental wear can be a factor. Also wear manner in how you subject your car will factor into it.
The short story is you could go 150,000 miles and not have issues or drive 15,000 miles and have issues. It's hard to simply put a figure that accounts for mileage and time.
I think one thing though that needs to be reiterated more and more that for most everyone in all situations EBCM failure does not completely ground the car into undriveability situations. Unlike the column lock issue that often strands the car, a failing EBCM is simply going to negate the ability to use traction control, ABS, and/or active handling (if equipped). If you do not mind your dash being lit like a Christmas tree and lacking the ability to use those type driving aids then pursuing a used module can be put on the back burner.
It only has 16000 miles and has spent it's winters in a garage.
This car does not have active handling or the sport (Z51?) suspension, just the base suspension.
Funny, I have just logged on to figure out my same problem, code C1214. I have a 2001 vert with 20,000 miles. Can someone be a good corvette brother and respond on how to remove the EBCM incase tonight after some more trouble shooting I need to send it out for repair.
THANKS
THANKS
Received 1,261 Likes
THANKS
THANKS
Thanks for the info. I found that and will try the repair myself. Can't hurt and I cleaned all grounds and replaced 5 year old battery, drove several miles and still have current code C1214. One odd thing is that I can't seem to reset these history codes of B0361 and B0441.
St. Jude Donor '09-'10, '14
It's common enough there are businesses that specialize in repairing them.
How's that for common?
It's also common enough that mine doesn't work. Now someone tell me how to turn off those annoying lights so I can get on with my life. Why they put any of that stuff on a car puzzles the mind.
The company that repairs these are in business to do repair on ALL electronic components from ANY car. There's no business that only repairs Corvette EBCM's.
