Heating / AC
Heating / AC
2000 Corvette - I'm sure there has been a ton of post on this but here we go, getting hot air out of driver side and cold out of passenger side. When I tap on the cabin temp sensor the unit works on auto but then goes back to not working. also the heat adjustment dose not work unless you put the temp at 60 degrees then you get cold air, the whole system works like crap.
2000 vette hvac
Thanks I will look at that, but im have the hardest working this system. I press auto and only get cold air on my side would that part do that seem no matter what I set it at its too hot or too cold
