Cracks in Polished Thin Spoke Wheels
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
I've been searching for some polished wheels, considering making a change. I've seen several on CL, ebay and talking with guys who own them, cracks can develop, especially where the spoke meets the outer rim. But I've also noticed that I'm only seeing this problem on polished wheels, not on the painted spoke wheels. Is that just a coincidence or is there something to it, that the polishing process makes the wheels more prone to cracking? Anyone have any info on this?
Neighbor
I doubt that the type of finish, high polished vs. painted would increase the possibility of one wheel over another to develop hairline cracks. If your in the market for these wheels just make sure you inspect them for possible cracks and make sure they are true.
Just noticed your in Holly Springs, I'm in the Sunset Lake area.
Received 19,298 Likes
'20-'21-'22-'23-'24
Now that you bring this up, I too have seen reports of cracks developing on the high polished wheels but don't recall any of the painted ones doing that. Would be interesting to hear if anyone with the painted wheels have had that problem. I've had both types and thankfully no issues with any of them.
The polishing process should not create cracks. The polished wheels are also forged which should be stronger and less prone to cracking than the standard cast C5 wheels. The ZO6's are also forged but painted.
I would need to get a cracked wheel and examine/dissect the area. I've done failure analysis on aluminum and other metals/welds in the past to see if it was fatigue or a defect to cause it.
Cracking is more common in magnesium wheels. We in the Pantera community do a number of things to ensure they do not have cracks or don't later crack when we "properly" restore a wheel.
regarding cracks in wheel....
I know ours are supposed to be "polished" alum wheels so this may not explain this situation, but FYI, chrome when used is a durable but BRITTLE coating so it can lead to crack initiation on the surface that propagates into the base material. So, yes, finish can influence cracking.
See ya around HS/SL road!
