How long did the battery last in your OEM Fob?
and have you got a spare? can you have more then one?
as we all know the GM fobs aren't the best, I got a new one from Stu's remotes, really helpful guy, and worked great.. until today..ordered new batteries, hoping thats what it is, although I'm not a heavy user of the car... so hoping its not something more terminal..
how often have you changed your battery?
I was thinking about having a spare, but not sure if you can pair more than one with your car?
I have one of theose window valets, so need mine working as it makes getting in and out of the car in the garage much much easier!
The fob looks exactly like the one for my Buick. When I broke one for that car, I found replacements on-line -- EBay, if I recall correctly. I don't recall how I programmed the new fob, but it was probably like this:
Yes, you can have two that work.
Love that window valet.
How To Program A GM Remote, GM Remote Initialization Procedure - YouTube
I agree, the window valet is one of the best items I've bought!
getting in and out in a tight garage is a breeze!!
Received 19,305 Likes
'20-'21-'22-'23-'24
As far as I know, my Fob still has the original battery in it and that would be nearly 12 years. I know I have not changed it and I've owned the car for 5+ years.
And yes, I have a second Fob for the car.
The clip that holds the battery in place and doubles as the negative contact has a rather flimsy solder joint to the circuit board, and depends somewhat on the case holding everything in alignment. I've seen at least two fobs where the joint had failed and made the fob intermittent. If your battery only lasted a year, it may not be the battery's fault: 5-6 year lifespan is pretty normal on a daily driver, longer for the weekend/summer crowd.
(That's for the 2001+ system...I've never seen one of the older ones.)
Re the multiple fob question, the system can be programmed to recognize up to three fobs. I'm pretty sure the cars all originally came with two, that's how it works with every other GM car I've ever owned.
I'm a firm believer in having three keys: one for daily use, a spare in the kitchen drawer, and one without a fob to give to valets/mechanics/whoever so I don't have to try to pry the car key off the chain if I have to leave the car somewhere.
I've got a 2000 GM vehicle (not the Vette) that still has the original batteries in both key fobs (and both still function as they should). Close to 15 years now, so yes, the batteries can last a loooooong time.
Now I've just jinxed myself. They'll both probably quit on me any day now.
Edit: I should add that the two key fobs for my 2004 Vette also still have their original batteries in them. That's 10.5 years and still going strong.
thanks Guys
thats doesn't sound good! if some of yours are lasting 6 yrs +
it may be its broken..
Received 2,681 Likes
2018 C5 of Year Finalist
Original owner with two original fobs, both with original batteries. Weekend driver however.
I haven't had to replace my battery yet, but I know one thing... these fobs are the most touchy fobs I have ever dealt with in my life!!!!!
I have the problem of somehow hitting the trunk button or alarm button as I'm putting my keys in my pocket it seems at least 2 to 3 times a month. The alarm when it goes off seems to be very tough to turn off after several presses on the fob. By the time I get it turned off and look up everybody and their brother is staring at me. Drives me damn crazy.
It would be helpful if you posted the year of your car in the question. There are two different C5 fobs, one for 01-04 and one for 00 and older. The older fobs are known to be intermittent and can sometimes be fixed with soldering the connections. (go to Google and type in "legendary problem solved, corvette forum") You'll see the thread with how-to. The newer fobs (as well as the older ones) can just get out of sync with the rolling code. All you have to do to resync the fob to the car is hold down the lock and unlock buttons at the same time until the horn honks. Of course, this only works with fobs that are previously programmed through the DIC to your car. Before you buy batteries or fobs, try holding down the two buttons at the same time and see if you get a honk. If this doesn't work, you can try the batteries and resoldering. You can program up to three fobs for a car, but all programming must be done at the same time. If you program a new fob, the old one will be erased, so get all the fobs together and do them at the same sitting so they will all work. Doesn't matter what order you program them in, the first one will become fob 1 for the memory settings and the second one fob 2, etc.
ah OK is holding down the two buttons a check that at least the fob has life in it and maybe needs resetting?
that would at least rule out one thing.. I will try tomorrow
No! Reread my post above. I explained how it syncs the rolling code, it's not a test. IF the fob and car are out of sync, this will re-sync them. It is not a test OR a reprogram.
Actually bit of a result.. I have found my old fob as well in my oddments box.. one I thought was bust before getting my new one last year... never come across any of these threads before, so I think I will also try soldering up this one.. and might end up fingers crossed having two working ones...
OK, just for info for any of you guys that are interested..
found a link to a guy on you tube who bought a fob on Ebay for £8, $12 he said and it works... worth a look? cheaper than a soldering iron!
links below
http://www.ebay.com/itm/New-Keyless-...-/121329641861
links below
Little update...
some guys saying it hasn't worked for them, some say it does!
but for $12 with shipping and battery maybe worth a punt?
