I need help installing new radio in 1999 Convertible with power antenna
4th Gear
I need help with understanding the installation of a new radio in a 1999 Convertible with power antenna.
I'm looking to install a Kenwood Exceleron KDC-X798 with XSVI-2004 Wiring Interface.
The XSVI has a blue/white wire that states to connect to the amp turn on wire of the aftermarket radio.
The KDC-X798 has a blue/white wire that states to connect to the power control terminal when using the optional power amplifier, or to the antenna control terminal in the vehicle.
The KDC-X798 has a blue wire that states antenna control wire. The directions state it is NOT USED.
I believe I should connect the KDC-X798 blue/white wire to the XSVI blue/white wire and not connect the KDC-X798 blue wire
What do I connect for the power antenna ?
Do I connect the KDC-X798 blue/white wire to the vehicle antenna control terminal ?
If so, where is it? or will the power antenna work after hooking up all connections ?
Additionally, I would like to install a switch so I can control when the antenna extends. When the radio is on, I'd like the antenna up when listening to the radio, antenna down when listening to cd/mp3.
What wires should I connect to the switch ?
I'd like to do this from behind the dash when Im changing the radio.
Hi mate, I'm certainly no expert on these, but I have a vert with std radio, and actually went route of using a Tom TOm with MP3 capability instead..
However search for Denis at DD mods .. he is the man on Audio side including also dash board solutions for fitting bigger units in etc etc.. wealth of knowledge and well known on here...
there are other vendors too who I'm sure will help..
good luck
good luck
Looking to install an aftermarket radio in my '99 coupe.
*EDIT* Actually, just ordered a single DIN package from DD.
you might get more results posting this in the General/audio /electronics area. I did this to my car , but its been too long, but I have a toggle switch for the antenna.
