Portable Battery Jumper
Does anyone use or have any experiences with any portable battery jumpers? I have a battery charger for the garage and a beast of a portable battery charger I bought many years ago, but I'm looking to get something that is more convenient. With lithium-ion batteries, there are now portable battery jumpers that are small enough to fit a glove box. My question is, do you have one? Have you used one? Are there particular features that I should look for?
I believe Chip at CCA sells one that you can fit in your back pocket.
I have this jumper.... not small enough for glove box but fits in rear storage compartment. About 50 bucks. 900 amps
http://www.cloreautomotive.com/sku.php?id=239
I've been looking at this one:
http://www.geniuschargers.com/boost/
I saw someone post on Facebook about using it at a speed event. This guy used it to start (among other cars) a late model ZR1. However, I'm concerned about their stated limit of 6.0 L engines. Has anyone used this one or have any alternatives? I'm going to check CCA and see what they have to offer.
St. Jude Donor '09-'10, '14
My wife and I both have one, but it's not the glove box variety. She has used hers several times, while I have only used mine maybe once on a lawn mower. (she is always helping people even though I tell her not to for safety reasons)
Make sure you keep them charged up though.
What worries me with that one is the power. Only 200 amps. The one I found is 400 amps is suppose to be for engines up to 6.0 L. I was hoping someone had some real world experience with one of these and could let us know if 200 or 400 or 600 amps were needed.
I have a concern, but not the knowledge to know if t applies in this situation.
A skilled member here, a retired electrical engineer, advised me to use care with battery chargers, as most all emit a square wave that the computers don't like, and if exposed to this wave form, can cause problems.
I had been charging my battery off the top posts while it was still connected via the side posts, thinking the battery would cushion the voltage, because it was kind of a problem to remove the posts, and other cars didn't mind similar treatment.
My concern with a jumper is the electrical wave form generated, which I do not know. FRom a battery it might be a regular wave shape, and not the hazardous square wave generated from a transformer, and probably is ok.
Just a detail you might check. I don't think anyone cares enough to investigate a non problem like this.
Received 19,299 Likes
'20-'21-'22-'23-'24
Several years ago while at the St. Jude's check presentation, the battery in my C5 decided to go bad. Luckily, forum member Savewave had a portable jump box in his car and was able to successfully jump start my car.
For Christmas that year, I got as a gift a Peak Portable Power System 300. It has 600 peak amps and while not able to fit in a glove box, it is pretty portable.
dc electricity
Anyway i am a new member, i have an 84 and 85 vette. i do most if the mechanical work in them but am an electrician by trade I.B.E.W
The one I have would not fit in the glove box, and certainly not a C5's glove box. It also has a very nice air pump with gage. I've never used the jump function, but the portable air pump is so handy, I use it even in the garage, all the time.
Cruising
Battery jumper
Here's the one I have:
About the size of an iPhone 6 only thicker. I've used it to start cars and trucks and it works great. Fits in the glove box.
Amazon.com: UNYSON Ultra-Portable Power Bank- Smallest Car Jump Starter w/400 AMP Peak- 8000mAh Capacity, 5 Colors with Wrapping Bag (Black): Automotive
My buddy has one of the small ones, it could fit in your pocket. I saw it jump a totally dead PT Cruiser. I was amazed. Most of the ones I've seen have USB ports to charge phones and a short set of jumper leads that plug in . I think lowes has them for $99.
St. Jude Donor '15
i keep this one in my car
https://cranktools.com/products/juice-bar
have even jump dual battery ford f250 trucks
