"Low Oil Level" light came on = Oil Pressure fluctuations?
So my low oil light came on the other day, I checked the oil, it looked fine - just under halfway on the 01+ dipstick. Checked it after a ride home and waited 15min before checking. It was just below max after sitting for at work for 8 hours.
This morning light came back on, oil pressure higher than normal. Checked after work after 15 min again after getting temp to about 170 showed around the bottom hashes of of the dip stick. Put in half a quart I then it looked to be half way. Drove home, noticed oil still fluctuating from 35psi at idle (low) and 61 around 5k rpm in 2nd. Parked it at home after the oil temp reached 190 waited 15 (more likely 16 this time) now it's showing higher than earlier but no longer half way.
This dipstick is new to me so it's a learning process. Liht hasnt been back on since I added and when it came on and I reset it it never repopulated for that ride. Just curious as to if I should add more or not and of the pressure flucautions are normal.
Thanks guys!
Thanks guys!
Pressures are excellent, no worries. As for the check oil light, it's likely the wires leading to the oil level sensor are shorting somewhere. In my case, my longtubes melted them so I had to be sure to route the wires away from the headers during the repair.
I thought about the shortage but I do think it is likely properly triggered, I just can't find out how to read the dipstick and for some reason I always get a residual line from pulling it out.
Is it supposed to be half way or at max? How many quarts does the total hashmark area represent?
If your level is within the hash marks it definitely shouldn't be triggered. Not 100%sure on hash marks, but 7 quarts in mine reads right at the top of the hashes. My low oil level light will set when the level is about a quart below the hash marks if that makes sense
It should be at the top dot, and yes, the hashed area represents one quart. It should take 6-1/2 quarts to fill. It's possible you're just seeing the results of oil sloshing within the pan. It happens to me every time I head out to the local lake, and always at the same place.
Okay well I guess I'm gonna pour the rest of the quart since half only got it half way. The oil light hasn't been on since but I started it this afternoon in 40 degree weather (just a note, it's been colder and the oil pressure has been lower) car sat at around 60psi until warm then fluctuated from 35psi (lowest at idle) though avg idle was 40-45psi; highest was 64 psi near redline. I'm assuming these are normal pressures?
