New Home.
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
New Home.
New home being built, You think I will have an issue getting the C5 in the garage?
Received 3,812 Likes
St. Jude Donor '03-'04
I've seen this pic many times before, and keep thinking it can't be real. Surely, surely no builder would do that. What vehicle could traverse that grade & still be low enough to clear the garage door?
Or maybe this is a family full of motorcyclists on enduros. That sounds like a much better idea
Received 19,299 Likes
'20-'21-'22-'23-'24
Get some of those Fat Daddy's or Fat Momma's and some Fangs and you'll have no problems tackling that driveway.
Received 2,681 Likes
2018 C5 of Year Finalist
Bet the owner doesn't have a front splitter...
you could also use a rail system the would pick your car up at street level then winch it up to the rail, then allow the carriage to retract into the garage..
BTW there is a house a few block over that has a much longer but similar angle to engage top get into the garage... Ill have to grab a photo of it.. its for sale also.. 750K.
Supporting Vendor
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Mine is not quite that bad, but about as bad as a C5 could manage...
Worst part is the house they built right behind my garage has their Living Room right at the edge of the alley. You can see the neighbors move to the far side of their house every time I put it up on the KwikLift...
This one is old enough that the crown vic was showroom fresh when it was taken.
