Please help: what bulbs should I buy for my C5 headlights and fog lights?
I want better illumination, I'm not mechanical, and I want to order bulbs to have my mechanic install. Thanks to all of you who have been so helpful to this new C5 owner and Happy Thanksgiving!
If you want to stay with the stock housings, the 9011/9012 HIR bulbs are the brightest available. They cost about $100 for all four bulbs. make a big improvement over stock. If you want the best available aftermarket systems, go with either Radioflyer's projector lights or the European OEM headlights. Both of those will cost between $500-$600. Here's a link with a lot of information on all choices.
https://www.corvetteforum.com/forums...t-upgrade.html
Changing bulbs is not hard:
Modifying 9011/9012 bulbs to fit C5 housings:
HIR bulbs:
http://store.candlepower.com/hirlighting.html
HI-4 harness lights all 4 bulbs on high beams
https://www.corvetteforum.com/forums...just-20-a.html
HIR bulbs:
Supporting Vendor
Order here:
http://shop.radioflyerinnovations.co...lights-015.htm
Compare to factory:
Same camera, same settings, Radioflyer Headlights LOW BEAM
Never out-drive your headlights again:
Only Radioflyer Headlights come with:
- Bi-xenon projector optics (each projector has low and high beam mode using a single HID bulb)
- 70w Ballasts that ensure correct headlight rise/lower function WITHOUT a resistor
- Complete plug-and-play installation without the need for long relay harnesses.
