Radio interference
By any chance, do you have a convertible or a fixed roof C5?? The radio antennas on these cars are located close to the tail lamp housings and that may be a problem.
You should closely check the ground wires at the wire harness connectors at the housings and the ground posts on the rear frame rail to make sure everything is tight and free of any corrosion or rust.
