Tire Pressure Issue
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It is winter time and when cold the pressure in the tire goes down maybe 3 to 5 lbs and as you drive it the tire warms up and pressure goes up.
Received 19,284 Likes
'20-'21-'22-'23-'24
Check the tire pressure when the tires are cold. Make sure it reads 30 psi and then see if the message appears. If it does and you know you have the right air pressure in the tire, could very well be that the TPS is going bad.
The OP said the sensor reported the tire flat, not low on pressure. Your explanation would be valid if low on pressure but not flat.
