My reverse lights are uneven...one is mcuh brighter than the other
I have two different sets of LED bulbs and the left side is twice as bright as the right side. Weird.
Has anyone else experienced this?
Flip the bulb around. The stock bulb used in the reverse lights are dual filament (1157, commonly used as brake bulb or turn signal in other cars) except there's only contacts for 1 filament so if it's installed one way only the low filament turns on and if you flip it around both filaments turn on. I'd assume the LED bulb is a stock replacement and thus has 2 sets of LED strips rather than 2 filaments.
Reversing bulb worked perfectly!!
