C7 Wheels on C5 Base model
Old 02-27-2015, 03:23 PM
SG Lou
SG Lou's Avatar
Saw your post on Facebook s well....They do look great but something about a spacer that just doesn't sit right with me...
Just paranoid i guess
Old 02-27-2015, 10:33 PM
MilleniumVette
MilleniumVette's Avatar
When I first saw the post I was skeptical. But, I actually kind of like the way they look on your C5. Very nice.
Old 02-27-2015, 11:54 PM
Mastersorbet
Mastersorbet's Avatar
Originally Posted by B747VET
I think they look great on your car! But, those C7 caps absolutely have to go.
Agree with the center caps. I'd like to get c5 ones or I may just get blank ones and either custom make my logo with vinyl or just buy decals.
Old 02-28-2015, 12:29 PM
thegame
thegame's Avatar
Just don't put those hideous C7 tail lights!!!
Old 02-28-2015, 05:01 PM
NOMOREWORK
NOMOREWORK's Avatar
St. Jude Donor '13-'14-'15
Those wheels look awesome on your car !
Old 04-28-2015, 08:58 AM
1SG_Ret
1SG_Ret's Avatar
Those look great. Hugh improvement IMO over the stock C5 wheels.
Old 04-28-2015, 10:12 AM
jjc508520
jjc508520's Avatar
They'd look fine on my pewter '00 FRC! What about the tire sizes - say I find the wheels and want to put my current OEM-sized tires on them?
Old 04-28-2015, 02:34 PM
VetteFTW
VetteFTW's Avatar
They look awesome! This also makes me feel a little better about the 1/4" spacers I run with stock C6 wheels in the rear on mine. I was also scared they weren't safe, but if yours are 3/4" and you don't have any problems then I should be good to go.
Old 04-28-2015, 06:14 PM
linz5
linz5's Avatar
LoL!....I was preparing to post the same comment!......the wheels look great on the c5 by the way.
Old 07-16-2015, 11:22 PM
Eric_The_Jew
Eric_The_Jew's Avatar
The caps "have to go" huh? What are you, a gay hairdresser?
Old 07-17-2015, 09:37 AM
Mastersorbet
The entire car is gone!
Old 07-17-2015, 09:47 AM
imlowr2
imlowr2's Avatar
The 3/4" spacer is much better, I'd even go with a 1/2". What did you do with the TPMS on the wheels? Did you have to replace them with the originals to avoid an error?
Old 07-17-2015, 10:36 AM
  #33
Mastersorbet
I had to use the oem tpms. Not that big of a deal.
Old 01-24-2016, 08:02 AM
  #34
OVEREXTENDED2015
OVEREXTENDED2015's Avatar
Default Likewise!
I'm with you brother, something about 100mph+ speeds, and spacers, does not settle well with me. We have a George Bush Tollway, in Grand Prairie Tx, where 70mph speeds are acceptable, and I some how manage to find a stretch where I can go 100 plus. I think I will go with the C7 replicas, I believe they said, designed for my C5 on ebay.
Old 01-24-2016, 10:26 AM
  #35
alxltd1
alxltd1's Avatar
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Ah come on....let's finish the conversion
Old 03-28-2016, 11:41 AM
  #36
Internetguru
Support Corvetteforum!
Internetguru's Avatar
This thread inspired me to put OEM C7 Z51 rims on my C5. Seeing your fit with 1" and 3/4" spacers was a huge help!
Fronts fit perfectly. For rear fit I used a 5/8" Doug Rippie Motorsports spacer & 2.5" ARP chrome molly studs.
https://www.corvetteforum.com/forums/c5-general/3800500-new-shoes-for-my-millenium-yellow-2004-c5.html
Last edited by Internetguru; 03-28-2016 at 12:05 PM. Reason: wrong length ARP studs I used 2.5" not 3.25"
Mastersorbet (03-28-2016)
Old 12-14-2016, 07:49 PM
  #37
Mastersorbet
Default Re: C7 Wheels
This should become a sticky!
To C7 Wheels on C5 Base model
Old 12-15-2016, 07:25 PM
  #38
doublenut9
doublenut9's Avatar
I think that looks really good. Does that mess with the speedometer or any of the other electronic stuff?
Old 12-15-2016, 07:43 PM
  #39
Mastersorbet
I had to re-adjust the spedo by using hp tuners. The difference is very minimal...but I'm really ****.
Old 05-19-2019, 06:51 PM
  #40
ricksright69
ricksright69's Avatar
Default C7 Take off wheels on my 2002 C5
I bought original C7 take off wheels all 4 for $500 shipped off ebay and went with BORA USA made adapter $240.00 for the adapters and $1,030.00 for the new Michelins NON run flats this time as run flats are WAY too rough because of the thicker side walls. Now the car is MUCH more comfortable to drive. I used a 2/8th spacer up front with EXT lug nuts and went with 22mm out back. I think my new Michelins are a little stretched out back even though they are the exact same size that came on the C7 from the factory. Had I known this ahead of time I would have gone with 25mm or slightly wider rear tires I don't like the "stretched look." The front 2/8th spacer is perfect up front. I also ordered a set of 4 1 and 1/4th inch spacers so I installed my C5 wheels on my 1987 C5 and they look great on that car. The bad thing is I just bought new run flats for the C5 wheels only 4 months ago so they only have maybe 300 miles on them. I don't drive the C4 and haven't registered it since I have owned it about 8 years ago. I bought the car for my uncle 15 years ago at the Sheriffs auction it belonged to some drug dealer who tried to run over a couple of cops. It had sat in the Sheriffs impound yard for 5 years. So in the last 20 years it has only been driven about 20 miles if that. C5 wheels on my C4 C7 wheels on my C5.
Not4spd (05-21-2019)
Quick Reply: C7 Wheels on C5 Base model
