B&M T-Handle Installed
Hi guys, over the weekend I figured I'd change up the look in my A4 so I decided to change out the shift ****. I wanted to go with a T-Handle and found this Aluminum B&M one for under 30 bucks from Summit (part number 80941) I also purchased the C5 A4 shift adapter to install the T Handle. Install was very very easy, less than 10 minutes. Snapped a couple pics.
Received 19,219 Likes
'20-'21-'22-'23-'24
Not a bad new look.
My high school car was a 65 rag top GTO... with a T handle 4 speed shifter... still miss that car.
mike v
Looks great, put the same one on my 01 6-spd stock.. Drilled & re tapped. Apmx 45 min..
I like the look and feel...
I didn't have to drill or tap anything, the handle threaded right onto the shift adapter. Although I didn't use them, the handle did come packaged with many different adapters for use with other vehciles. I think it looks much better and feels a lot better than the stock shift as well. Now I have plenty options if I ever want to change shift *****.
This is the one I bought
http://www.ebay.com/itm/VMS-Corvette-C5-Automatic-Auto-To-Manual-Shifter-Shift-****-Adapter-Kit-Lever-/291168459873?pt=Motors_Car_Truck_Parts_Accessories&hash=item43cafe1c61&vxp=mtr
What you will actually need is the C5 Automatic Shift Adapter Kit. This kit allows you to install any aftermarket shift **** with the 9/16-18 thread pattern. To shift gears all you have to do is push down on the **** itself.
VMS Corvette C5 Automatic Auto to Manual Shifter Shift **** Adapter Kit Lever | eBay
I'm likin it
I want one with the thumb button on it to operate my line lock, then a custom "Jake" on it rather than the B&M logo...there must be a way
I just think the "T" handle is the best ever! But my wife want's nothing to do with it. What can I say? It's her car. In fact I switched to an "Eight Ball" type shift **** and after a couple months she made it very clear that she wanted the stock **** put back on.
Like it. Nicely different. Had same one on my '70 Z28 stick. I wouldn't put one on a stick today, but really works on the auto.
Too bad Hurst doesn't make the dual gate auto shifter to fit the C5. I had one on my old '79 Z28 with a Hurst T-Handle. Auto mode on the left side, swing across to the right side for manual mode.
