Lowering 2004 Coupe
Old 02-25-2015, 11:55 PM
stc
stc's Avatar
Default Lowering 2004 Coupe
I am enjoying my recent acquisition and keep reading that folks have lowered their car by reversing the bolts on the stock shocks. (hope I am saying that right).
Can someone explain the process, how much it lowers the car, and if there any issues.
Thanks,
Stephen
Old 02-26-2015, 12:09 AM
Uhhtaken
Uhhtaken's Avatar
Location: Jacksonville,nc and Williamsburg,va North Carolina and virginia
There are many guides within the forum explaining all of your questions, just gotta use the search function.
Old 02-26-2015, 03:32 PM
2FAS4UU
2FAS4UU's Avatar
Old 02-26-2015, 03:43 PM
jdvann
jdvann's Avatar
This might help....http://frankhunt.com/FRANK/hobbies/c...5_Lowering.htm
Old 02-26-2015, 04:33 PM
mstromquist
Support Corvetteforum!
mstromquist's Avatar
Received 3,860 Likes on 1,670 Posts
2015 C5 of the Year Winner
The backs are easy. Just loosen the bolts that go through the spring on each side until you get the right height you want. The fronts are not to bad either. Just turn the bolts on each side of the spring counter clockwise until you get the height you want. The fronts can be a bit tricky sometimes though. If they are corroded in the springs then it will be a little more work. Mine were corroded so bad I had to take the spring out and work the bolts in a vise to get them to turn. Read some of the links that have been posted and you will have a better idea of what it's all about.
Old 02-27-2015, 09:01 AM
raydawg357
raydawg357's Avatar
Here is a good one: http://www.digitalcorvettes.com/foru...ad.php?t=26211
Old 02-27-2015, 03:26 PM
stc
stc's Avatar
I was looking to just adjust the bolts as it is much easier as see how much of change occurs.
The information is great and the links make it look easy so will try it.
Thanks to everyone,
Stephen
Old 03-02-2015, 02:20 AM
striper
striper's Avatar
Originally Posted by 73Corvette
Just lowered the rear on my FE1 suspension about 3/4 of an inch which is max without re-alignment. Looks better to me and was very, very simple. I didn't want to mess with the fronts... just wanted to sit level and equal wheel space in the fender wells.
Your car should not sit level. The front should be around 1/2" lower than the rear for correct alignment.
To Lowering 2004 Coupe
Quick Reply: Lowering 2004 Coupe
