Turn signals
Turn signals
My turn signals on my 03 coupe have started not working intermittently.
They will go for a while working OK, then just stop, or you can turn it on and it flashes 3 or 4 times than stop. All of the lights work. Emergency flashers work fine.
Last night they quit working and I stopped for dinner, then got back in the car and they worked, but only for 5 minutes. After another 5 minutes they worked again.
Almost seems like the flasher is getting hot. Anyone know if the turn signals and emergency flashers use the same flasher? Do these cars even have replaceable flashers?
C5?
Hazardous Turn Signal Relay Switch is starting to go out. The turn signal is also within the Hazard Relay Switch.
Next time your turn signal goes out, tap above the Hazard Relay Switch. If they come back on, you're in for a real treat swapping that out.
I replaced my hazard switch by removing my knee bolster and reaching up behind the switch. I have some small arms and it was still tight reach though. Took all of maybe 15 min, although 13 of those minutes was getting two small screwdrivers back there to free the switch. Just another option if you don't want to remove your center console and radio brackets. Good luck Sir.
Big Jay, if you are having issues with the left and right turn signals it would be the Hazard switch. In the above post there is a link to where I describe 4 ways to resolve the issue. If it is not an issue with both sides we need to know.
If you have any questions, feel free to PM me and we can discuss on the phone.
Mr. Sam
Mr. Sam
Yes, both sides. Never one side works and the other doesnt. I will try tapping above the hazzard button when it hapens again and see if that works. Then I will know I need to replace that switch.
I removed and replaced mine but i opted to relocate mine to just under the carper under the side of console for easy access if it needs replacing again. I just replaced the hazard button back in the original location for looks only. Mr sam is the man on this item
