Aftermarket BRIDE Seats, What Brackets and Sliders?
Cruising
So I purchased some aftermarket Brideo VIOS III seats from a local but I've never installed aftermarket seats. To put these in my C5Z I would need brackets and sliders correct? Any recommendations on brackets and sliders? I was looking at these:
Do these look right to those with seats?
Seat brackets:
And Sliders:
Seat brackets:
And Sliders:
Well I don't know a whole lot about the Bride seats, but I was able to fit Sparco Fighter seats in my convertible on the stock rails. I used a pair of side mount brackets from Sparco and fit them to the stock power seat rails. I'm sitting a bit high for my liking so I may make my own brackets this summer but still retail the stock power rails.
Width wise the Sparco seat just barely fits (shoulder bolster just touches the door panel) but height wise there is clearance (on top of the power rails too). Unless the Bride seat is very tall, I probably wouldn't worry about height too much.
You can see the dimension chart on this page and compare to the seat you bought:
http://www.sparcousa.com/product/fighter
Cruising
i wasn't aware there was a way to fit the a side mount racing seat onto the stock power rails. So you have a link to the brackets you used or any pictures of your setup? Dimensions wise it appears the should bolsters are smaller on the seat I'm using so hopefully they fit well.
I am looking to try to install these here next week and will be uploading pics, just waiting for the snow to clear here in Denver.
P.S. Thanks for all the info so far
unless you ordered them from japan there is a very good chance those seats are fake. 80%+ of the bride seats in the usa are counterfeit. some of the fakes even get the takes to look very close
at least google what the authentic seats look like and compare. the cloth is often a give away as well
the fakes have not been tested and will likely not hold up in an accident
that seat from a US based authentic retailer like evasive costs you $3400 a pair in carbon. used is around 2500 if they are in good shape.
the fiberglass is cheaper but even still $1800 a pair new
great seats if real, comparable to a recaro pole position
I used these brackets from Sparco (I think an older model, but should still work)
http://www.sparcousa.com/product/side-mount-steel-0
It's quite simple though. Remove the stock seat from the power rail (probably the most difficult part, but there's a write up somewhere if you search around). You'll be left with 4 studs pointing up.
Loosely mount the side mount brackets to the side of your seat so it sets the width of how your brackets will sit. Then drop the seat with the bracket attached onto the studs of your power seat rails. Tighten them down with some locking nuts (I think I used flanged nuts).
Use some cable ties or industrial velcro to mount the seat control module to the bottom of your new seat and clean up the wires. You will have some unused connectors if you previously had the inflatable bolsters on the stock seats.
Re-install and have fun!
The seats will probably sit a little high on the stock rails (mine do) but I don't think I mounted them in the lowest holes on the side mount brackets... I'm going to redo that this summer.
You will likely need to invest in some seat belt extensions if your Bride seat is a fixed back. My Sparcos are, and the seat belt receptacle is a b**** to get at. Some 3" extensions make life good again
