Help! Fan Control on Fritz!
Hey Gang,
Little help / advice here?
1999 FRC, 95k miles or so. The heater makes heat, the AC makes cold. The slector **** (defrost, high, high/low) works and sends the air where it needs to go.
Problem! The fan selector is a dial, 0-5. The only fan setting that works is 5(full blast) or off (any other position).
What's wrong? What's the fix?
Thank you!
Thank you!
Resistor pack on the blower motor has fried all but one of the resistors.
Go to post #5 in this thread for a picture of your problem:
https://www.corvetteforum.com/forums...elay-hvac.html
This guy? http://tinyurl.com/kmzs9ab
rock on!
