Spring Time SC + Projects!!!
Delays and Vendors are killing my timelines !!!
The guys at County Corvette have made such great progress on my car, now they are waiting on parts I ordered a few weeks ago that are yet to be delivered.
Why can't vendors just tell you if stuff is going to be delayed??? Some do others don't. Above all, I am surprised at this one vendor-I have bought from them before and remember much better service. This time they left me without communication and I'm still waiting on my parts.
Another delay was caused during the rebuild of my torque tube. Once the new driveshaft was ready and they went to finish up the torque tube, they noticed a slight issue. As you can see by pic of the aluminum coupler below- NOT THE RIGHT MEASUREMENT!!! Not thick enough, WTF!!!. How do you sell stuff and not know whether they are or are not correct??? Luckily the shop looked into this and realized the issue. I had to order another one-went with another poly for quicker delivery:
The car will get all fluid changes, load base tune, re-install the hood and trim and fire up at least in the next couple of days. Once they get my remaining drive train parts in, they will finish the rear end and hit the dyno. Once that's done, its time to pay the piper and get it picked up!
The Alky control kit is something you can add whenever you see fit if at all.
Some of the few things I've learned since having mine, you definitely want to read some of the do's and dont's on the Alky web site if and when you decide to add Meth, the meth is pretty harsh on pump itself and with proper care you can go several years without having to have the pump rebuilt. (Not that it's expensive) just some good info.
Enjoy that bad *** ride
Received 1,261 Likes
damn dude your couplers were trashed!... how did you not notice something before, or did you?... unfortunately there are some bad vendors out there and I have had the displeasure of dealing with some of them myself... some people just don't care any more, they are quick to take your money but just leave you stranded waiting on parts with no communication or when you get the parts they are wrong... then all you get is an I'm sorry and wait another week or 2 for the right stuff... in my opinion when they screw up like that they should be overnighting your parts with a return label
Yep your going to be having some fun there's nothing like the first time you have the gas on the floor, just make sure you have a lot of room, your also going to love that clutch, definitely a smart move.
As for the vendors, I guess that the most used vendors aren't always the best. In those cases I just wish they could have told me about the delays so I wouldn't look like such a dope with the shop or even more important, send me some shipping info. Then the parts show up and ofcourse there's a slight rubbing issue which required attention so that cost to get fixed.
As for selling me the wrong crap, I contaced the vendor, that item is going back for a refund for sure.
Axles In, Drive Train In...slight issue pops up......
So the rear axles finally made it in from RPM and surprise, a slight issue..... Now I had SKF Race Hubs and Bilstein Shocks installed a while back so they have been on the car since 2013. It appears that the lower mounts for stock vs. Bilstein are quite different. The new axles went in the car and were rubbing up against the lower shock mounts as you can see below. So the mounts had to be dealt with in order to make some space for the axles. According to the shop, they spoke to RPM and they said that this happens every so often due to aftermarket parts and size/thickness difference. The way they clearance the shock mount is the same way RPM has done it in the past so I should not have issues in the future.
Back Together and Dyno- 594 RWHP/551 RWTQ.
So County Corvette got the car back together and tuned today! I got the email while I was in the middle of a meeting. Honestly, at first I was a bit disappointed with the results. All of the money spent and to only see 111 RWHP and 100 RWTQ increase seem like a let down. I sent James at CC an email real quick. His reply basically told me 3 things: 1.) that they wanted to keep it safe, 2.) the car's set up has potential for much more 3.) I quote "Mike (tuner) ran out of mass air meter which is an issue with 97 & 98s". Not sure what to make of that last one but not being an expert in the matter or knowing if there is a way around it, I have to take their word. They have always treated me right so I trust them.
I guess I was so focused on the number of "600RWHP" or more that being below that kinda bummed me out for a bit. I was like WTF???. After really thinking about it for a few, I'm more than happy with that...for now. In reality, I just want to get my car back so I can drive it! Meth would have likely put me above that so now I know what my next quick project is gonna be when I get chance.
SO HERE IT IS
Now the file that was scanned and sent to me today had a VERY VERY light torque and A/F lines and they only used red and light red so I went over them in MS paint so I could seem them better. If you want to see the original, just see this link: (original file)https://www.corvetteforum.com/g/picture/3315969
Today after A&A Super Charger 593.9 RWHP/551 RWTQ
2013-Before with Cam Only LS3 482.6 RWHP / 441.3 RWTQ
SO HERE IT IS
Thank you! You know, I just said that same thing in the FI section. I'm no expert about anything and know nothing about tuning but I was always under the impression that with FI I would see the A/F leaner than that.
do you have a wideband in the car?... if it really is that rich no doubt it needs to be leaned out some... I'm also curious why power started to drop off around 6k... how much boost did you see?... add meth and you might consider a 2 bar map sensor and a speed density tune... I think your car has a lot more in it, nothing against the guys that did the work (it appears they did a pretty good job) but maybe you can find a tuner that is a little more experienced with these setups to unlock some more of your cars potential
#34
Picking the Car Up Today!
Getting ready to go pick the car up this morning! I decided I will revisit the tune later. I need to get the car picked up while I have the chance, work and other stuff keeping me busy.
James from County Corvette sent over some shots of the car, car looks great. I'll get some shots of the engine bay once I get it back. I mentioned in another thread that I liked how the gage pod and white face gages match the dash gage cluster.
#36
Holly crap..... I was not expecting this to be such a freaking beast!!! It is so much of a difference between the car I dropped off and now. I realized there are certain things I can't do now so I have to adjust driving a bit. Way too much fun
