Need part number !
Need part number !
Need a part number for the chassis fuel feed pipe on 1997 C5.....
Was changing fuel filter and noticed the end is burred up, could explain why the fuel filter was leaking..
Thanks for any help in advance
Call Marc at Vettenuts.net 1-615-896-6100 He may be able to help you.
Be SURE to specify '97 year model ('98 probably the same). The fuel systems on those two MYs are unique.
There are fuel line repair kits with various fittings, different size hoses, retainers, splices, etc, made specifically for nylon fuel lines (very important). Dorman makes them; available through many AP stores.
fuel feed line
the part number for the fuel feed line with the check valve in it is
10413424. looks like it goes from the fuel filter back to the pump pressure line
ITEM #12 here:
The part number you indicate, I'm finding is "NLA".
Last edited by LoneStarFRC; 04-02-2015 at 12:01 AM. Reason: add info/ad correction
